OEM Xenon in Base
Old Feb 28, 2005 | 10:19 PM
Speedy11's Avatar
Speedy11
Default OEM Xenon in Base
Has anyone swapped the OEM Xenon HID headlamp assembly into their base model 350Z? Just wondering if it is a bolt in affair. Do the harnesses match? are there any different mounting points?
Old Mar 1, 2005 | 07:50 AM
Speedy11's Avatar
Speedy11
anyone? i've searched but i haven't found any posts of people swapping in the entire headlamp assembly.
Old Mar 1, 2005 | 08:07 AM
Z-INCOGNITO's Avatar
Z-INCOGNITO
I had mine done by someone who knew how to do it... but it was not a straight bolt on... major modification was needed... the headlight circuit plugs are different (HID headlights vs non HID headlights)...
Old Mar 1, 2005 | 08:23 AM
Speedy11's Avatar
Speedy11
Thanks for the info. Was the housing mounting direct fit?
Old Mar 1, 2005 | 11:45 AM
L337350's Avatar
L337350
PM Jun .. I think he knows a lot about this
Old Mar 1, 2005 | 12:44 PM
nkohler's Avatar
nkohler
I got a OEM HID kit from Jun, it is very easy. Basically remove the front bumper, remove the headlights, plug in 2 things and put it back together. No splicing or anything. Took about an hour and I had no prior experience.
Old Mar 1, 2005 | 01:02 PM
Z-INCOGNITO
If you're talking about the actual housing... then its an exact fit... but the circuit plugs are different... i think it was 6 prongs vs 8 prongs (dont count me on that)
maybe a HID KIT would be an easier route... because you have to find spare OEM HID Headlights and that might be too hard or too expensive...
Old Mar 1, 2005 | 01:27 PM
Speedy11's Avatar
Speedy11
Actually I already have both headlamps from a totalled touring model. I guess I just need to find out how to wire them up.
Old Mar 6, 2005 | 12:38 PM
JerZe23's Avatar
JerZe23
I upgraded to 2k3 maxima hids.. left over from my old maxima that i traded. pretty easy swap... minor modification to the bulb base... and a few wires.
EnjukuRacing
Sep 30, 2015 06:55 AM
