Flutter noise at shut off
Old Apr 4, 2005 | 03:51 PM
itsahood's Avatar
itsahood
Default Flutter noise at shut off
I have an 04 6sp touring with 10k on it. When i turn my car off it makes a flutter noise kind of like the pullys are sticking or the bearings are bad. Ill try to get a better descrption. Does anyone know what this is? This brings me to my second question. Do i have to bring the car to get serviced at the dealer i bought it from or can i bring it to any dealer? Because im not too big a fan of the dealer i bought it from for services issues.
Old Apr 4, 2005 | 04:33 PM
Solrac's Avatar
Solrac
I have the same flutter noise. I've come to the conclusion that its a normal sound coming from the flywheel or somethin...
Old Apr 4, 2005 | 06:08 PM
bknezevic's Avatar
bknezevic
disengage your clutch (push it to the floor) and then turn off your car and see if it still makes the noise.
Old Apr 4, 2005 | 06:30 PM
DavesZ#3's Avatar
DavesZ#3
If you put your car in neutral and let out the clutch and turn off the engine, if you hear a sound coming from the transmission that sounds like marbles rolling around in there - then that's "normal". As bknezevic pointed out, if you repeat the process but keep the clutch pushed in, you won't hear the noise.
It happens to a lot if not all manual transmissions. We even checked some brand new ones on the dealer's lot to verify.
Old Apr 4, 2005 | 06:31 PM
SB Track's Avatar
SB Track
Clutch.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
