oil change woes
Old Apr 5, 2005 | 02:49 PM
smellslikecurry's Avatar
smellslikecurry
Default oil change woes
i just switched over to mobil 1 synthetic @ 7000miles and my car is knocking!!! do any of you know why its doing this???
Old Apr 5, 2005 | 02:59 PM
yobri's Avatar
yobri
Are you using premium gas?
Old Apr 5, 2005 | 03:06 PM
zand02max's Avatar
zand02max
Def. not the oil.
Old Apr 5, 2005 | 03:14 PM
smellslikecurry
ya i didnt think so but i noticed it right after i changed the oil...maybe because i was paying more attention to see if the car was acting funny after changing the oil...knocking usually has to do with the timing right? i havent messed with my z at all...just put in my popcharger about 4000 miles ago
Old Apr 5, 2005 | 03:17 PM
zand02max's Avatar
zand02max
Might want to clean your pop charger, or it could be bad gas!
Old Apr 5, 2005 | 03:18 PM
smellslikecurry
im gnna clean my pop charger tomorrow...gnna use the kn kit cuz i dont have instant acess to the jwt oil...i have half tank left...maybe i shud fill it up
Old Apr 5, 2005 | 03:28 PM
woodie's Avatar
woodie
I hope that you checked to make sure there's oil in the engine. If the oil was just changed and it started knocking, I'd make sure they put oil in it.
Old Apr 5, 2005 | 03:32 PM
smellslikecurry
5 quarts of mobile 1 put in by yours truley
Old Apr 5, 2005 | 03:33 PM
ANXIOUZ's Avatar
ANXIOUZ
With other cars, the only time I had knocks was because of crappy low-grade gas. Maybe you got regular instead of premium? Try a different station next time.
I would recommend filling up with premium at another station now. That might help a little until you can get a clean hi-octane tank again.
Old Apr 5, 2005 | 03:36 PM
smellslikecurry
i told the guy premium maybe he put in regular??? but then id be getting really shitty gas milage...ill get gas from another station and clean the popcharger...if it stills knocks then time to bring it to nissan
Old Apr 5, 2005 | 03:45 PM
Z-INCOGNITO's Avatar
Z-INCOGNITO
maybe you should let him in
JK... sorry i couldn't resist. good luck on your car tho
Old Apr 5, 2005 | 04:33 PM
smellslikecurry
lol!! i usually pump my own gas...(i work part time at hess)...but i was in a rush and it was pouring outside
Old Apr 5, 2005 | 05:37 PM
King Tut's Avatar
King Tut
You know you have to poor the Mobil 1 in the engine after you drain out the old stuff right. . I would make sure your plug is tight and that you have enough oil in there or you will kill that motor real quick.
Old Apr 5, 2005 | 06:13 PM
350Zenophile's Avatar
350Zenophile
Did you stick with 5/30 or try something heavier?
Old Apr 5, 2005 | 07:44 PM
Hogstar's Avatar
Hogstar
Good luck let us know what you find.
Old Apr 5, 2005 | 07:53 PM
capnfrantic's Avatar
capnfrantic
Check the oil!!! Hopefully there is the right amount in there... If so you have been had by a Red Sox fan! He probably put regular in. Seriously keep us posted.
Old Apr 6, 2005 | 06:07 AM
Z-Z's Avatar
Z-Z
Right - double check the oil fill plug. It might not be tight! Never hurts to re-check.
Old Apr 6, 2005 | 08:36 AM
BigMike's Avatar
BigMike
Is the car KNOCKING or PINGING? Huge difference.
If the engine is KNOCKING at idle or when revving the engine not under load, don't start it back up until you get it checked. That is a lack of lubrication problem.
If the engine PINGS under a load, that is a gas, timing problem.
Old Apr 6, 2005 | 08:42 AM
tekk's Avatar
tekk
excuse the newbie question: how do you know if your car is knocking or pinging?
Old Apr 6, 2005 | 08:47 AM
ANXIOUZ's Avatar
ANXIOUZ
Yeah, I dunno the difference either. I guess it depends on when the noise happens: At idle or while pressing down on the accelerator.
It sucks here in Oregon....we can't pump our own gas. So I have to crane my neck and squint through the port hole to get a look at what the attendant is doing.
