how do u repalace the running light bulbs?
Hey I got a350z and was curious the stock running lights are like a yellow color, i want to replace them with a bright white led light bulb, How the heck do I do that? Do I have to remove the bumper or pull out the whole head light? or can i take of my front wheels and remove the splash/mud gaurd and get to the bulb from that angle?
The front running lights you can replace by removing some of the 10mm screws and clips in the fenderwell. Once you pull back the fenderwell a little bit you will have access to the bulbs. I also changed my turn signal bulbs to clear ones. The ones in the front you can get to without removing anything although it is a little tight. The rear ones you have to remove the taillight assemblies. Open the rear hatch, you will see three round plastic caps on each tail light. Remove those with a little screwdriver and then unscrew the 10mm bolts underneath them. Then the tail lights just pops out. Then reach your hand down into the bumper. Hope this helps, later
