grinding
Old Nov 21, 2002 | 11:59 AM
dragonbz99's Avatar
dragonbz99
Default grinding
dammit, today i was on a hill and i was comign to a stop but not really and i tried to hold my position witht he clutch then i wanted to shift to first but forgot to depress the clutch all the way and i heard 2 grinding sounds at my shifter, did i just kill my transmission? please help guys
Old Nov 21, 2002 | 12:03 PM
CoachZ's Avatar
CoachZ
Default Re: grinding
Doubtful. Just don't make a habit of it
Josh
Old Nov 21, 2002 | 01:14 PM
Boomer's Avatar
Boomer
Is it still grinding? If it isn't, its probably OK, but do NOT use your clutch and throttle to hold yourself on a hill unless its only for a split second, use your handbrake and release it as you raise your revs and release your clutch; it should be a similtaneous release. If you use the clutch and throttle to hold youself on a hill, you will burnout your clutch quickly.
Let the person behind you honk, use time enough to get it right and you will save your clutch believe me, and forget about embarassment; get it right!
Old Nov 21, 2002 | 06:32 PM
Brad4rdHay's Avatar
Brad4rdHay
, usually in higher RPMS when the shifter wont fall into gate as easier/quickly as it does in the lower RMPs.Its ok, (well not OK but not the end of the world). I have done it three time
BlinkerFluid
Sep 8, 2015 10:06 AM
redlineRED350z
May 22, 2003 07:52 AM
elektrik_juggernaut
May 6, 2003 08:01 AM
themyst
Apr 26, 2003 04:05 PM
BYOB
Apr 17, 2003 07:19 PM
