engine rattles,taps at start up
Old Apr 15, 2005 | 10:54 AM
unit5alive's Avatar
unit5alive
Default engine rattles,taps at start up
Hi guys got a noise at start up 03 track,sounds sort of like a lifter noise,any idea,only does it for 1-1.5 seconds,only when cold at first start up,thanks in advance,Craig.
Old Apr 15, 2005 | 12:27 PM
1z4u2c's Avatar
1z4u2c
cold start huh? maybe your oil is too thick for conditions. or very low?
Old Apr 15, 2005 | 02:50 PM
milos's Avatar
milos
my friend is experiencing the same problem...what should i tell him to do ?
Old Apr 15, 2005 | 04:38 PM
1z4u2c's Avatar
1z4u2c
check his oil level, if it's ok. change his oil to something thinner , if that don't work. take it to the dealer
Old Apr 16, 2005 | 04:23 AM
unit5alive's Avatar
unit5alive
update, you can feel it in the clutch pedal as it makes the noise,seems like the starter is staying engaged a little too long ,oil is factory weight,and full,car only has 3k miles,but hasnt been driven in 6 months.
Old Apr 16, 2005 | 04:30 AM
CESAROTORRES's Avatar
CESAROTORRES
Unhappy I have the same problem!
I have the same problem, The oil level is fine and the weight. I change the oil at the dealer since I have 3 free oil changes. Total mile on the car 9000.
Cesar
Orlando Fl
2004
350ZR
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
