oil filter
Old Apr 20, 2005 | 06:10 AM
Reggi914's Avatar
Reggi914
Default oil filter
My nav tell me that i need to change the oil filter. I have about 23000 miles on my car. I just got an oil change last week. How long did it take you guys to need to change your oil filter?
Old Apr 20, 2005 | 08:09 AM
Penguin's Avatar
Penguin
Oil Filter should be changed with every oil change. Not sure if the Z has some special filter or maintenance schedule.
Old Apr 20, 2005 | 08:21 AM
DG39's Avatar
DG39
You can do it your self if you have two portable ramps aviable at auto zone or pep, etc.
Problem is on touring you have to take off panel fitted under engine. Has about 12 bolts in it give or take one or two and a center clip. Takes about 30 minutes and is pretty easy after you get the panel off.
Old Apr 20, 2005 | 08:27 AM
mpowers's Avatar
mpowers
I thought he said he just had the oil change done. The light needs to be reset, check your owners manual.
Old Apr 20, 2005 | 10:06 AM
Reggi914's Avatar
Reggi914
Yes, this is why i am asking. How do i make sure they actually did change the oil filter? Anyone know how to reset the light? Its coming up on my nav screen everytime i turn the car on.
Old Apr 20, 2005 | 10:24 AM
zand02max's Avatar
zand02max
Change your mileage on the NAV feature. I did mine when I changed the oil at 500 miles.
I am not at my car so I forget which buttons to press, bt its def. within the Nav unit that you update. I'll check later today when I get home if you don't figure it out!
Old Apr 20, 2005 | 10:41 AM
RED HOT Z's Avatar
RED HOT Z
press the info button thats where it tells you your maintenance schedule then click on both oil and filter and reset them. You can put what mileage to change the filter and oil. It's quite easy to do
Old Apr 20, 2005 | 10:47 AM
zand02max's Avatar
zand02max
Yep thats it.
Old Apr 20, 2005 | 03:28 PM
Reggi914's Avatar
Reggi914
cool, thanks for your time guys.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
