Rattle at shutdown/turn off
Old Apr 21, 2005 | 09:38 AM
fahrenheit350's Avatar
fahrenheit350
Default Rattle at shutdown/turn off
I've searched the threads and it doesnt seem a lot of ppl might have this issue. When I turn off the engine I hear a rattle for a split second coming from underneath the car. My initial thought was loose exhaust mounts but didn't seem so when I looked under. I have a a stock exhaust, is this normal? Again, its like metal vibrating against metal for a split second right after shutdown. Thanks.
Old Apr 21, 2005 | 09:41 AM
projectmrod's Avatar
projectmrod
yea i have the same thing...
usually you hear the normal purr of the exhaust when you shut down the car but it seems like something is slowly cranking/rattling down at shut off.. its probally more annoying than anything serious
Old Apr 21, 2005 | 10:17 AM
rxtrom's Avatar
rxtrom
Sounds like the heat shield it rattling against the Cat.
Bast thing to do is get it on a lift and shake the exhaust. Maybe you'll find the rattle.
If it is the heat shield its only alluminum and can be bent.
Old Apr 21, 2005 | 12:16 PM
1 2 NV's Avatar
1 2 NV
I know this sounds crazy but i was cruising the boards one day and I found a post about a rattle noise at shut down coming from underneath the car like near the tranny and the guy suggested pushing in the clutch and hold it in then turn your car off. And that should take care of it. And believe it or not it friggin worked! Now maybe its some thing else with your car but it wont hurt to try it.
Old Apr 21, 2005 | 12:36 PM
JThrilla's Avatar
JThrilla
I always hold the clutch in until I turn the car off because I leave the car in first gear when it's parked (with the emergency brake on of course). How else would you handle this? Put the car in neutral, release the clutch, then turn off the car? hmmm...
Old Apr 21, 2005 | 01:14 PM
Nforce1's Avatar
Nforce1
I have the same thing. I hate it when I shut off the car, it rattles under the car.
Old Apr 21, 2005 | 01:19 PM
DavesZ#3's Avatar
DavesZ#3
It's a fairly well known "problem". If the car is in neutral and the clutch is out, when you turn off the engine you will hear a rattling noise from the transmission as the engine winds down. It's normal according to Nissan.
Old Apr 21, 2005 | 05:48 PM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
Thanks for this...I have the annoying rattle as well. Will engage clutch before shutdown!!
Old Apr 21, 2005 | 07:36 PM
smoothludey's Avatar
smoothludey
it's the clutch chatter thing that's plagued almost everyone with a 350z...some say it's a bad throw out bearing, some have had their trannies replaced...but it's so common it sounds like it's normal.
Old Apr 21, 2005 | 07:52 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
My Z has done that from the get go...
Im over 60k, dont worry about it.
Old Apr 21, 2005 | 08:59 PM
apexi97tsi's Avatar
apexi97tsi
1 2 NV:
Thanks for mentioning that clutch trick. It worked for me! Now it won't sound like my car is falling apart upon shutdown. LOL!
Old Apr 22, 2005 | 10:15 AM
fahrenheit350
Thanks to all. I tried it this morning and to my surprised, it worked.
Its really sad that our cars make soo much rattles, clanks and bangs... (and its considered normal) I'm not use to weird noises since I use to own an 84 300ZX (datsun) and 91 300ZXTT, those were built like tanks. Anyways, its good to know my car isn't falling apart.
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
Lee3Z
Nov 1, 2002 01:39 PM
PrototypeStan
Oct 25, 2002 06:00 PM
