Putting calipers on the wrong side of car...
Old Apr 24, 2005 | 01:18 PM
Huckingfellers's Avatar
Huckingfellers
Default Putting calipers on the wrong side of car...
Is it possible to put the rear calipers on the wrong side of the car. They are not marked like the front! Non Brembo 04 touring 6spd 18" I cant get my brakes right and I am starting to wonder if the rear calipers are on the wrong sides of the car . Have air and cant get it all out. Even after taking off caliper with line attatched putting wood in there and moving caliper while bleeding an air bubble popped out of each rear. But still only have about 60% stoppinbg power.
Old Apr 24, 2005 | 02:28 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Hrmm... havent thought about this yet... but I think the calipers are the same part number per side... meaning the same...
Ill check the part numbers on monday to be sure...
Old Apr 24, 2005 | 02:32 PM
Huckingfellers
Cool that would be nice. If I were to switch sides from where they are now the bleeders would be more near the top of the setup. As they are now the bleeder is at the botrtom of the setup.
Old Apr 24, 2005 | 03:47 PM
1z4u2c's Avatar
1z4u2c
Default hellyeah!!!
My educated guess would be if the bleeder valve is on the bottom of the caliper then "hellyeah" its wrong. it should always be on top.....
Old Apr 24, 2005 | 04:59 PM
bigdaddy's Avatar
bigdaddy
make sure the larger piston is toward the front of the car (down) and that the bleeders are pointing up.
sean
Old Apr 24, 2005 | 05:25 PM
Huckingfellers
sean
HUH? The bleeders can only face up even if i do have them on wrong, regardless they always face up, LOL
Old Apr 24, 2005 | 06:06 PM
2003z's Avatar
2003z
No they don't. I just happen to have my brembos off right now, refinishing them in candy apple red, and have a spare set of non-brembos. Here are 3 pictures of the same brake. The first is the brake by itself.
Attached Thumbnails Putting calipers on the wrong side of car...-rear-brake.jpg
Old Apr 24, 2005 | 06:07 PM
2003z's Avatar
2003z
this is what it looks like if you have it on the wrong side:
Old Apr 24, 2005 | 06:08 PM
2003z's Avatar
2003z
This is what it should look like. If you've done this, don't feel too bad, you aren't the first and won't be the last. I did it on my 240Z and even the shop had a hard time figuring it out, and one of my powdercoating clients recently did the same on his 350z. Notice how in both cases the bleed valve points towards the front of the car, but in the wrong one, the bleeder is below the point where the brake line enters the caliper and on the correct one it is above that point. That is what you want.
Attached Thumbnails Putting calipers on the wrong side of car...-correct.jpg
Old Apr 24, 2005 | 06:45 PM
Huckingfellers
Sweet 2003z you are da man again . I do have them on wrong. In other post I thought you were talking about the painting calipers thread i posted. Spoke before I read a lil farther, oops. Thanks a whole shitload guys for all your help!!
Old Apr 24, 2005 | 07:06 PM
2003z's Avatar
2003z
no prob, just happy to help!
Old Apr 25, 2005 | 09:12 AM
Jason@Performance
Performance Nissan
yeah... different...
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
