Help, can't get it off!!!
Old Apr 24, 2005 | 02:32 PM
Destiny350Z's Avatar
Destiny350Z
Unhappy Help, can't get it off!!!
I was washing and waxing the Z, and I'm one of those girly girl that wears nail polish!! Anyways, I rubbed one of my nails against the car on accident and now there is this long pink streak on the side!! To make things worse I waxed over it I washed and rubbed but I can't get it off, I'm afraid that nail polish remover will remove more then the nail polish!! Oh what to do, what to do!! Well I know I will never wear nail polish while washing and waxing again!!...........nail polish+ Z= pink streak
Old Apr 24, 2005 | 02:35 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Take nail polish and wash your car with it, I heard it cleans the car real well.
Old Apr 24, 2005 | 02:40 PM
Destiny350Z
You my friend, are not very helpful
Old Apr 24, 2005 | 02:42 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Old Apr 24, 2005 | 02:44 PM
Destiny350Z
Old Apr 24, 2005 | 02:48 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
post *****
Mantis3024's Avatar
Mantis3024
hold a blow dryer up to it few seconds and use a clay bar to rub it off
Old Apr 24, 2005 | 02:49 PM
SteveTX's Avatar
SteveTX
First try some rubbing alcohol then try mineral spirits. Wash area right after and apply fresh wax.
Old Apr 24, 2005 | 02:53 PM
jcpeyton's Avatar
jcpeyton
Try a light rub with menzerna intensive polish to remove, then another light rub with menzerna final polish. Then wax. Without a polish/remover, you're just waxing over the nail polish. I'm sure other quality polishes will work-I have had such good results with menzerna that I plug it every chance I get.
Old Apr 24, 2005 | 02:54 PM
Destiny350Z
post *****
You callin me a post *****..well you you you..... all around *****
Old Apr 24, 2005 | 02:55 PM
Destiny350Z
thank you very much!!
Old Apr 24, 2005 | 02:57 PM
Destiny350Z
Thanks..I will try it
Old Apr 24, 2005 | 02:58 PM
Destiny350Z
where do I get a clay bar?
Old Apr 24, 2005 | 03:08 PM
zand02max's Avatar
zand02max
Pep Boys, Auto Zone, ect
Old Apr 24, 2005 | 03:19 PM
Destiny350Z
thank you
Old Apr 24, 2005 | 03:36 PM
Netko350Z's Avatar
Netko350Z
Clay 100%...Stuff is f'in great!!!
Old Apr 24, 2005 | 04:19 PM
EatMyZ's Avatar
EatMyZ
Yup, Claybar should do the trick. Make sure you get some sort of lube though, god don't try and rub the bar dry across your paint.
Old Apr 24, 2005 | 04:33 PM
Sensation350Z's Avatar
Sensation350Z
This one`s easy:
Nail polish remover!
Old Apr 24, 2005 | 04:59 PM
NzZ's Avatar
NzZ
Even easier than claybar, you can try rubbing compound. The 3M stuff is cheap, and I'm pretty sure it'll pull the nail polish off with a lot less work than the claybar. You can pick it up at walmart, and it is totally safe for the Z's finish.
NzZ
Old Apr 24, 2005 | 05:12 PM
Reggi914's Avatar
Reggi914
i also think you should heat it up slightly and use a clay car. Try vinager also, though im not sure if would help much.
