Cai Problem?!
Cai Problem?!
ok so it has been raining here often (FL). every time i drive the Z when it rains, it runs poorly. i have a AEM knockoff CAI with the AEM bypass valve. according to everything i have read and heard, with the bypass valve it shouldn't matter even if i were to totally suberge the filter. i have even been careful not to drive through any standing water. no matter, it still idles badly and sputters a bit. i guess i am going to change it out for a popcharger and polished intake tube. any comments would be a great help and much appreciated!
Best of luck with whatever you decide to do. I wouldn't get an CAI, just for that very reason (also in FL).
I've heard that the performance aspect of the popcharger is similar to that of the CAI.
I posted a link in the other thread answering your question.
Good luck!!
Good luck!!
reset the ecu
Originally Posted by need Z
Clueless on that one man. Try going to autozone or somewhere and pulling the code?
Any link for what you are referring to??
http://www.technosquareinc.com/350reset.htm
Originally Posted by disturbed2483
here is the link to what he was reffering to
hey all, just so you know i unplugged the battery for about 3 hours and put back on and let the car idle for about 10 minutes. everything is basically back to normal, guess i may have sucked some water into the filter!
08-06-2021 06:19 AM
