only 59MPh in 2nd @ redline???
Old Nov 30, 2002 | 04:05 AM
LA-Z's Avatar
LA-Z
Question only 59MPh in 2nd @ redline???
I can only get to 56 MPH (digital)at redline (which is like 58 MPH Speedo), well shifting RIGHT at redline, before I get fuel cutoff. I thought it was 62MPH??? Does this indicate a problem with my ride? ANyone else get to 60+ MPH with Maual tranny?
Old Nov 30, 2002 | 04:15 AM
CaneZMD's Avatar
CaneZMD
That's strange. I have the six speed and I can get to about 62, or so in second gear right at the red line. Maybe your gauges are off because the gearing in all the cars is the same. I mean, 6600 or so rpm with the same gear ratio should give everyone the same speeds at redline in second gear. So maybe your gauges aren't calibrated right or somethin??
Old Nov 30, 2002 | 05:24 AM
Zmeflyby's Avatar
Zmeflyby
i get 60+....
Old Nov 30, 2002 | 06:18 AM
NiZZan's Avatar
NiZZan
Charter Member #77
Default 60+ MPH
I also get 60+ mph. 6mt touring.
Old Nov 30, 2002 | 08:11 AM
Radian's Avatar
Radian
Default Re: only 59MPh in 2nd @ redline???
Did you change your tires/wheels to a different size?
Old Nov 30, 2002 | 08:23 AM
CrazyBosnian's Avatar
CrazyBosnian
I get to 75!
Old Nov 30, 2002 | 08:36 AM
Stailey's Avatar
Stailey
it could be the gas u use also...what grade r u using
Old Nov 30, 2002 | 09:21 AM
sakred's Avatar
sakred
this seems to be a problem in my loaner track Z as well. i only get 58 mph at the top of my second. but it seems that my digital speedo and the analog one are in sync. i have to use the momentum i get from second to hit 60 without shifting to third. i hope this isnt the case on my touring Z
Hammad
Old Nov 30, 2002 | 12:39 PM
3502GO's Avatar
3502GO
I got to 59 on my old superblack Performance. I sold it and now have a redline performance, I will try it as soon as breakin in completed to see if this car is different.
Old Nov 30, 2002 | 02:03 PM
spf4000's Avatar
spf4000
Unless you changed your tires, this seems to indicate a problem with your speedometer. You might want to have the calibration checked.
The only other problem might be your tach is off, and the rev limiter is kicking in too early, but this is less likely.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
