rust on front bumper
Old May 31, 2005 | 04:40 PM
adrenilan's Avatar
adrenilan
Default rust on front bumper
i have rust on my front right fender in a paint chip what should i do.
Old May 31, 2005 | 04:55 PM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
I would clean it, prime it and paint it before the rust gets any worse.
Old May 31, 2005 | 05:00 PM
jcpeyton's Avatar
jcpeyton
+1. Or, take it to a bodyshop you trust and have them do it. The important thing is not to wait. Rust Never Sleeps.
Old May 31, 2005 | 05:01 PM
2004z's Avatar
2004z
Sleeps in 350Z
I would wait.
Old May 31, 2005 | 05:03 PM
Jun's Avatar
Jun
sand it, prime it, paint it, clear coat it.
OR
take it to the body shop so they can do the above
Old May 31, 2005 | 06:04 PM
rjpaterson's Avatar
rjpaterson
Z Enthusiast
Old May 31, 2005 | 06:34 PM
StefanZ's Avatar
StefanZ
Go find a rust inhibitor pen meant for rust removal in paint chips - most auto parts stores carry such 'pens'. It contains a hard fiberglass tip that abrades the rust away from inside the chip while limiting the damage to the paint around the chipped area. Once it is clean of rust, carefully dab primer in the chip, and quickly wipe off excess that bleeds beyond the chipped area. Allow to dry. Then, using touch-up paint (w/brush) purchased at a Nissan dealer (so it exactly matches - have the parts guy know the paint code of your Z to ensure a match), dab the paint in the chip. Light dabs with several coats stands up over time better than one huge dab. Technique depends upon your paint color (PPW takes more effort and skill). Go to http://www.langka.com/ and buy some - it allows you to blend the height of your repair seamlessly into the original paint. I have some and it works well if you have the patience to do it. GL.
Old May 31, 2005 | 06:53 PM
yobri's Avatar
yobri
Happened to me before also. Used Bondo rust remover and then used some touch-up paint...
https://my350z.com/forum/maintenance-and-repair/76095-paint-chip-rust-your-diy-recommendations.html
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
kyin
Oct 15, 2015 05:54 AM
