Alternative to JDM key
Old Dec 3, 2002 | 05:52 AM
Chris's Avatar
Chris
Default Alternative to JDM key
Check out this link its a mod on a subaru site. I dont know it it will work with the chip in the Z's keys but if any one is feeling bold they can try it out.
key mod
Old Dec 3, 2002 | 06:49 AM
VandyZ's Avatar
VandyZ
Cool, I would try it but our chip is in the plastic, not on the key. But you got me thinking!
Old Dec 3, 2002 | 05:02 PM
Chris's Avatar
Chris
lol 102 views and 1 reply... Im interested in how the chip works does it have to be physically connected to the key or is it a transponder like ezpass. I dont have a Z Im savin but i have a 2000 sentra w/o the chip and the valet key is the perfect shape for the bottom side of the nissan key fob.
Old Dec 4, 2002 | 06:58 PM
flynnibus's Avatar
flynnibus
Z Flier
Based on comments in the manual about interference with other devices,etc.. I'd speculate its a transponder
Old Dec 4, 2002 | 08:11 PM
ares's Avatar
ares
Veteran
if it were a transponder, wouldnt it need a power source? I believe it needs to be attatched to the key and recieve power from the ignition.
Old Dec 5, 2002 | 04:23 AM
VandyZ's Avatar
VandyZ
No, the antenne is around the ignition hole. It just detects a coded chip. Much like a card to get in and out of a parking garage or like the speed pass for Exxon.
Old Dec 5, 2002 | 07:03 AM
Chris's Avatar
Chris
how is the chip mounted to the key is it soddered in or just glued to the plastic. Has anyone tried making a copy of the key and seing if it works with a real key in proximity to the column?
Old Dec 5, 2002 | 07:32 AM
VandyZ's Avatar
VandyZ
The chip is located behind a molded cap in the plastic coating. It can be removed if one is careful. A non coded key will start the car with a coded key near the column. I have tried this and it works (this is how most resolve the remote start problem). I am waiting on an extra remote to butcher that I bought off ebay. I am doing this mod. I have a uncoded key already cut and ready for surgery. The only problem with this is it will cost some money for the dealership to hook up to Consult II to reprogram all the transponders to your car. The remote can be done without Consult II. I have service manual and can provide directions if needed. So far the key cost $35 and the remote cost $15. The key programming will cost between $0-$60 depending on how good you can sweet talk your dealer. The remote programming wont cost anything, as you can do it yourself.
Old Dec 5, 2002 | 08:05 AM
ares's Avatar
ares
Veteran
why not remove the transponder from the key, and place it inside the FOB if theres room. nothing needs to be reproggrammed. but you do risk your key and you have to get the transponder out somehow.
Old Dec 5, 2002 | 08:23 AM
Chris's Avatar
Chris
vandy keep us informed on how it turns out and maybe post some pics on how to do it.
May 30, 2017 03:28 PM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
jdmctrek
Exterior
Sep 17, 2015 03:13 PM
