?? on some specs on the Z(03 Track)
on
Originally Posted by SB Track
Track has : LSD, TCS, VDC, light-weight Rays Engineering wheels 18", Brembo brakes, front and rear diffusers, rear wing, HIDs, and HomeLink over the base.
thanks for the info..
you bastards are really making me wanna get one of these things ASAP
on
Originally Posted by gerthiekins
the track i am pretty sure has the LSD and I have also heard the suspension ont eh track is diff as well, i am thinking this is true.
well now.. arent you just ontop of things ryan..
lol
indeed so i should def try and get the track edition then eh
on
Originally Posted by EnthusiastZ
The suspension on the Track is NO different than the other trim levels.
so then bassicly its just got the brakes and some slight aerodynamics changes??
on
Originally Posted by hndumafia
^^ and the rays wheels. oh and a lot less sound deadening material to lighten the weight a bit.
ok wait a min..... big turnoff there
i hate the road noise in my current car..
does the track edition have alot of anoying road noise?
on
Suspension Differences?
hmm.... it does have road noise...but i'm not sure if the other models won't. at worst, you can add some sound deadening. i have added some over the rear wheel wells, and will be adding some in the firewall area. i dont think it's too bad since i usually have my music on though. i would say you should go to a dealership and test drive a track and non-track model z, since there really isn't much of a difference between the 03's and 05's.
08-06-2021 06:19 AM
