Brakes need replacing after just 25K?
Old Jun 27, 2005 | 02:43 PM
TaliaZ's Avatar
TaliaZ
Default Brakes need replacing after just 25K?
I was told after getting my oil changed that I needed new brakes for $238.
Doesn't seem right. My brother's car (MR2 Spyder) has 80K on it and he never had to replace his brakes.
What's the deal? Am i just getting ripped off or what? No, I don't use them excessively or anything. They aren't squeaking, they work fine, and the rotors are not dug into.
Please help.
Old Jun 27, 2005 | 02:49 PM
s3fddiZ's Avatar
s3fddiZ
Shouldn't your warranty cover brakes which have premature wear???
Old Jun 27, 2005 | 02:53 PM
Vertex350's Avatar
Vertex350
It all depends on your driving habits. If you're unsure, get a second or third opinion from other dealers/ shops.
Old Jun 27, 2005 | 03:18 PM
Bertg's Avatar
Bertg
Definitely get a second opinion from a shop you can trust.
Old Jun 27, 2005 | 03:28 PM
Jaki's Avatar
Jaki
As long as you can feel that it brakes ok and does not squeal alot, you should be ok. Some shops just scare you and tell you all kinds of stuff, just to make money.
Old Jun 27, 2005 | 03:35 PM
Aggro_Al's Avatar
Aggro_Al
Your brakes lasted longer than mine. I replaced the front pads and rotors and around 16K and the rear pads and rotors at about 33K. If they aren't squeaking or look worn you should get a second opinion. They may just be trying to take advantage of you.
Old Jun 27, 2005 | 03:44 PM
yobri's Avatar
yobri
With enough hard braking (and frequency of), you can run the pads out in that amount of time. You should be able to see how much meat is left on the pad in order to determine if you're just being fed a line...
Old Jun 27, 2005 | 04:38 PM
drj's Avatar
drj
Well, you got double the life I did. I had to have new pads AND new rotors at 13k. I complained to Nissan and got the cold shoulder until I filed a formal BBB complaint. All of a sudden, everything was taken care of under warranty. If you look at any of the G35 forums you will find premature brake wear is an issue for them and Infinity actually extended a brake warranty for the G35 for 3 years/ 36k miles. To be honest though, 26k for new pads in a sports car is not all that unreasonable -- replacing (not resurfacing) rotors at that mileage is another matter.
Old Jun 27, 2005 | 06:06 PM
bodayguy's Avatar
bodayguy
I've got 23K miles and I need new front pads pretty soon. Planning to do them myself, however. I think the dealer told me it would cost $125.
Old Jun 27, 2005 | 07:59 PM
Zmeflyby's Avatar
Zmeflyby
i replaced my brakes around 13k or so. You're one lucky guy.
Old Jun 27, 2005 | 08:31 PM
dd55's Avatar
dd55
I just replaced my brake pads and resufaced the rotors at 23k. I know its probably average as others on here have to change it before 23k. Then again it could be the driver. I installed hawk performance brake pads and hopefully they'll alleviate the brake dust and last longer.
Old Jun 27, 2005 | 09:30 PM
Axl_GNR's Avatar
Axl_GNR
I just had my break pads replaced after 18K for $200 at the dealer.
Old Jun 28, 2005 | 05:31 AM
JonsilvZ's Avatar
JonsilvZ
25k miles is alot. Got mine replaced at 12k. I recommend Hawk hps. Got them online cheap and took it to a private shop where they charged me $40 for install. Came out to $125 total. OEM pads doesnt last long. The Hawks have over 15k miles now and there is at least 80% pad left.
Old Jun 28, 2005 | 05:51 AM
CESAROTORRES's Avatar
CESAROTORRES
Default For sale Brake pads
I can sell you my brake pads from a 2004 350Z the car had 1,500 miles on the pads and rotors when I upgrade to Brembos.
(50.00 dollars shipped)
Thank you
Cesar
Cell:407.963.2824
Home:407.281.0165
paypal and email: cesar@cfl.rr.com
Old Jun 28, 2005 | 06:00 AM
mpol99's Avatar
mpol99
Bought new OEM pads online for cheap & installed them myself at ~18K miles.
Old Jun 28, 2005 | 06:33 AM
Lerxst's Avatar
Lerxst
They'd have to be REALLY cheap... the brake dust is driving me bonkers on my car. But at 13K I've got squealling, so I'm going to Hawks, EBC, or Satisfied...
Old Jun 28, 2005 | 01:36 PM
woj666's Avatar
woj666
Along these lines, has anyone had to replace the Brembos and if so how much did it cost?
Old Jun 28, 2005 | 01:47 PM
jmagilto's Avatar
jmagilto
I replaced my fronts at 18K. I drive hard and brake hard. The whole job took less than 20min. The Z is quick and heavy with big sticky tires. Brakes wear just goes with the territory
jer
PS - the MR2 - which I quite like, weighs in around 1800lbs and its just not going to be doing 80 going into thrid gear. Poster child for long lasting brakes.
Old Jun 28, 2005 | 02:15 PM
Mirkod's Avatar
Mirkod
Hey there i have 33k on my z and im getting squealing everytime i press the brakes lightly at hard braking there is no squealing. My pads didnt look that worn when i took a look the other night, what could be the prob? ALso if i was going to replace my pads with aftermarket pads (more sport driving oriented) would they be harder on the rotor surface than OEM ones? Thanks
Old Jun 29, 2005 | 09:49 AM
TaliaZ's Avatar
TaliaZ
I'll get a second opinion and come back. Thanks, people!!
