TCS on or off?
Old Jul 4, 2005 | 08:13 PM
HighwaySpeed's Avatar
HighwaySpeed
If you're 35 or older, you probably know how to drive a car well, without traction control and or vdc.
Old Aug 22, 2005 | 08:41 AM
Clapton9286's Avatar
Clapton9286
Or if you've ever driven a car older than 1985...lol
Old Aug 22, 2005 | 08:47 AM
Nitrouz's Avatar
Nitrouz
Back to Z
on daily...off nightly.
Old Aug 22, 2005 | 08:49 AM
Clapton9286
I've never had the TCS off...and I want to do it today...what am I too expect? LOL@me being slightly frightened.
Old Aug 22, 2005 | 08:51 AM
Nitrouz's Avatar
Nitrouz
Back to Z
Standing stop. Rev to 3500. Slip/drop clutch. Floor the gas pedal.
You'll see the difference.
Old Aug 22, 2005 | 08:58 AM
Clapton9286
Aw man..lol...I can't wait..
How about through twisties and whatnot?!
Old Aug 22, 2005 | 09:11 AM
Zcool's Avatar
Zcool
Only on for rain, wet or other suspect road surfaces.
Old Aug 22, 2005 | 09:19 AM
MADDOG`'s Avatar
MADDOG`
On for daily driving, Off for the track, Off for spirited driving. I have VDC and the car seems to perform better (acceleration for the most part) with VDC off.
Old Aug 22, 2005 | 09:37 AM
sentry65's Avatar
sentry65
the burninator
I don't care what any of you say, TCS is dangerous.
You could be going thru a turn fast, go over some dirt, TCS kicks in, cuts the engine, the tail comes flying out, you hit the curb, crash into a tree
TCS has NO idea if you're turning or not. So as long as you do nothing but 100% straight line driving, then it's probably ok or safe to use. It wasn't engineered with turning in mind which is completely stupid
VDC is a different story
Old Aug 22, 2005 | 09:39 AM
Fletch69z's Avatar
Fletch69z
I always turn mine off as soon as I get into the car. I'd rather drive the car then have the car drive me, . If it's raining and I'm taking a trip or something where I know I won't be doing any type of spirited driving then I'll leave it on.
Old Aug 22, 2005 | 09:48 AM
JCat's Avatar
JCat
Originally Posted by nicolaycastro
there is an electronic device you can install to override the default setting from ON to OFF.
I am just a little lazy to look for it right now...
KP Technologies
OFF all of the time.
Here is where you can purchase this mod: http://www.350zfrenzy.com/forum/showthread.php?t=5903
Old Aug 22, 2005 | 11:52 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
You can actually get quite a bit a slip with the TCS on. I practice daily in my parking garage and it's not hard to get the tail out without activating the TCS.
If you hit a patch of dirt in the middle of a turn that makes the tires spin, hold on, TCS on or off the car is going to try to explore new directions of travel and you should probably be paying attention.
Chris
Old Aug 22, 2005 | 11:59 AM
350zRat's Avatar
350zRat
Turn it off right after starting the car. I do it without realizing it now. Just became routine. But i keep it on in the rain.
Old Aug 22, 2005 | 12:06 PM
sentry65's Avatar
sentry65
the burninator
Chris
yeah that's true, but one scenerio you have control of the car and can give the car more gas to try to regain rear traction. The otherscenerio is hold on for dear life, because even if you give the car gas trying to regain traction, the TCS won't let your inputs go thru to the engine
so it comes down to having control and a possible recovery vs no control and an inevitable wreck
Old Aug 22, 2005 | 05:57 PM
HyperSprite
Mad Scientist
Originally Posted by sentry65
...so it comes down to having control and a possible recovery vs no control and an inevitable wreck
If you had control a little dirt or sand would not have the wheels spinning so wildly that the TCS would take over.
If you play with TCS some more, you will find the only time it shuts you down is when the application of power far out strips the ability of the wheels to hold the road. Modulated additions of power at the threshold in and out of tire grip do not activate TCS.
Chris
Old Aug 22, 2005 | 06:16 PM
sentry65's Avatar
sentry65
the burninator
oh come on, you know that when TCS activates, it goes on for a good 2 sec before it shuts off regardless of if the tires did a quick slip or massive huge slip. When you're in a situation where you have little time to react, TCS can activate for just enough time to screw you.
A little tire spin and the tail briefly kicking out just a tad wouldn't keep you from making your corner, but TCS coming on and cutting the engine for 2 sec sure could.
Old Aug 22, 2005 | 06:37 PM
HyperSprite
Mad Scientist
And all I am saying is the TCS will allow you to step the rear out quite a bit if you modulate the throttle.
But whatever, believe and do what you want, makes no difference to me. If your TCS is snapping on like that, you probably should leave it off.
Chris
Old Aug 23, 2005 | 07:34 AM
  #38
pgh2atl's Avatar
pgh2atl
I turned mine off routinely when I get in the car now.
Reason being is that I had it on one time when I was leaving my apartment complex. I was trying to make a quick left across traffic with traffic coming from my right also. I accelerated to get across the traffic coming on my left. As I was making the turn to get get in my lane, the TCS kicked in & cut the power to the wheels. Wasn't a good feeling having the power cut as I'm looking at traffic coming at me both ways.
Since then, always off........
Old Aug 23, 2005 | 07:57 AM
  #39
sentry65's Avatar
sentry65
the burninator
yeah my car doesn't have TCS, my old one did.
My current one has VDC - which I pulled the fuse on because I got sick of stuff happening like what pgh2atl described
MAsSIVrOOM
Oct 20, 2023 10:50 AM
loudtoyz
Apr 6, 2023 04:52 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
lowbeeZ
East Canada
Mar 6, 2003 12:29 PM
2k3silver350z
Jan 16, 2003 12:12 AM
