2nd gear grind on my 05
Old Oct 3, 2005 | 07:15 AM
shifty711's Avatar
shifty711
Default Wow: This Seems All To Common
I also have the same problem on my 05 when shifting to second. I took the car to the dealership and the shop foreman drove the car. He said he could reproduce the problem but it was still up to nissan specifications. Which made me feel at ease for a while untill i visited this site and read all the posts about the gear grinding
Old Oct 3, 2005 | 07:29 AM
2JZfan's Avatar
2JZfan
it does seem possible that this 05 1-2 shift problem could be different than the 03-04 2-3/4-5 problem... my car only has 700 miles, the problem is it took me 5 months to get that many... i hardly ever get to drive it (obviously) and so if i have to wait until 5k miles or something until it goes away, I'll be dead by then!
at what mileage did yours go away? did it just all of a sudden go away or did it gradually get better? i've read that triple cone synchros can take more time to break in... I've also read that different fluid can make a night and day difference... i'm strongly considering some different fluid (like the BG Synchro Shift II) to see if it doesn't clear it up sooner...
Old Oct 3, 2005 | 07:57 AM
Amiricanmade's Avatar
Amiricanmade
i have a 05 with 2k on it and everytime i race my car won't go into 4th gear...like i put the cluth down and it wont go, i have put it in N....rev the motor up and try putting it into 4th. Its really bad. Has anyone had that happen to them before or am i the first?
Old Oct 3, 2005 | 09:13 AM
bamyi's Avatar
bamyi
My 5th gear started grinding at around 15k miles but I brought it used with 12k miles. The grinding then stoped for a few months. First the gears starting getting stiff. It took more work to get it into gear but it didn't grind. Then the grinding starts but only at high rpm, then it grinds at all rpm.
Old Oct 3, 2005 | 04:38 PM
EdgeOfSanity's Avatar
EdgeOfSanity
Originally Posted by tacomaboy
Yes, three or four new trannsmissions and lots of luck!
yep, im on my third and finally took it to the track last friday. Shifting as quickly as possible and i did not grind a single gear unlike previous trannys.
Old Oct 3, 2005 | 06:08 PM
FLZ_Boy's Avatar
FLZ_Boy
I have about 16k on my 05, but don't have any grind problems. Going into 2nd gear is a little stiff when trying to shift at 6400 RPMs in 1st, but still goes into gear without any grinding + plus a nice clunk sound.
Other than that, my Z is still in 1 piece.
Old Oct 3, 2005 | 06:43 PM
FairladyZ34's Avatar
FairladyZ34
I have an 05 Touring with about 800 miles on it and i have no problems going into 2nd near redline.
Old Oct 3, 2005 | 09:54 PM
Miko's Avatar
Miko
Maybe hte ones grinding are built in the Opamma plant. lol
Tochigi has quality right?
I think someone told me that nissan doesn't even make the transmissions, so why would one transmission work and not the other..its weird.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
pslamp32
Feb 8, 2017 09:07 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
