Down shift to First gear grind?
Originally Posted by Alberto
You people need to learn how your tranny's work-no $hit it wont go into 1st if you just push it in. Blip the gas and rev the motor so you just slide right in(rev match in) it will go smooth as butter...
I love racers
Your way more hardcore than me-how the hell did you get under 3000lbs
Is the Z your daily driver?
The Z used to be my daily driver until I got my first ticket in it. It seems to be away from home a lot since my sponsors work on getting it exposure or it is being worked on in one way or another
+1 learn to double-clutch on the downshift.
But if you're throwing it into 1st for stop and go (i.e. sequential stop signs) then just come to a complete stop. Never jam the shifter into a gear... if you are shifting correctly you barely need any force at all.
Originally Posted by bkknight369
Anyone else have this? The car shifts very smoothly through the gears, but when I'm comming to a stop from a roll, and try to shift into first, there is some resistence, and some very light noise (hard to hear unless windows are down and music is off).
Ideas? Should I have the dealership look at it?
My car has ~3800 miles on it btw
As for gear grind. I am not sure that what posters here are calling gear grind is truly gear grind. The Z transmission does "clink" especially from first to second. You NEVER want to hear the sound of gear grind. It is loud and horrible.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
