oil additives?
Old Jul 29, 2005 | 03:48 PM
drew76924's Avatar
drew76924
Default oil additives?
how do u guys feel about oil additives like lucus r they good, bad just wondering
Old Jul 29, 2005 | 04:03 PM
DG39's Avatar
DG39
Default Oil addative.
Just dump in a bottle of KY lub. it works the same way an oil additave does.
No ..they do nothing.
Old Jul 29, 2005 | 08:22 PM
jcpeyton's Avatar
jcpeyton
I'm interested in this question also. I've seen the Lucas displays w/ the hand-turned cranks that seem to demonstrate increased viscosity. I'm principally interested in whether there is ANY gain by adding this product to the pumpkin??
Old Jul 30, 2005 | 09:05 AM
SkiTTlez's Avatar
SkiTTlez
just go with sythetic..mobil 1 here, or you could go with royal purple.
Old Jul 30, 2005 | 09:49 AM
drew76924's Avatar
drew76924
well the car has only had mobil one syn so i was just wondering if anything would be better for it but i'll problably just stick with just oil
Old Jul 30, 2005 | 09:47 PM
MrGraphics's Avatar
MrGraphics
One of the things you have to remember about those hand crank things is, you cannot turn it as fast as an engine does. I saw a test where they spun a gear at the speed of an engine, and the oil with additives started to actually foam. Foam in oil is bad, it reduces viscosity and lubricating properties.
Oil or synthetic au-natural is the best solution - they spend millions making sure it is perfect.
Old Jul 30, 2005 | 10:24 PM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
www.bobistheoilguy.com
http://www.bobistheoilguy.com/images/lucas/lucas.htm
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
