6th gear
Old Aug 18, 2005 | 09:10 AM
silverspeedz's Avatar
silverspeedz
Default 6th gear
I have a 04 z and sometimes when driving normal and i shift into 6th gear it goes into gear but makes a grinding sound is that normal or should i get it checked out thanks
Old Aug 18, 2005 | 09:18 AM
Fletch69z's Avatar
Fletch69z
That's part of the recall for tranny problems. Do a search and you'll find more about it. There's a ton of threads.
Old Aug 18, 2005 | 09:19 AM
ssc's Avatar
ssc
dont sound normal....are u depressing the clutch all the way?
Old Aug 18, 2005 | 09:21 AM
King Tut's Avatar
King Tut
What gear are you going into 6th from? 6th doesn't like being shifted into after accelerating hard in a gear or when going from say 2nd to 6th. It is trying to tell you it doesn't like it and letting you know not to do it again. Now if we are talking about going from cruising at 50mph in 5th to 6th then there is a problem.
Old Aug 18, 2005 | 09:24 AM
silverspeedz
thanks guess ill get it checked out it does it ocassionaly when shifting from 5th to 6th just driving normal
Old Aug 18, 2005 | 03:35 PM
zBoone05's Avatar
zBoone05
I have an '05 and not sure if it would be the '03/'04 tranny problem or not, but I have experienced that it takes a deliberate effort to get into 6th gear. Simply put, I have to really push the shifter to the right when going from 5th to get it into 6th. I can't speed shift into it like 3rd and 4th.
Old Aug 18, 2005 | 03:46 PM
spacemn_spiff's Avatar
spacemn_spiff
I agree it does take effort for the 6th, but becomes easier after the break in period. Also might be a safety thing to accidentally prevent going into 6th instead of 4th.
Old Aug 18, 2005 | 06:21 PM
DZ2005's Avatar
DZ2005
I've got an 05 too and no probs with that at all. I sometimes shift from 3rd to 6th too and it's cool with that as well.
Old Aug 18, 2005 | 07:17 PM
SS350Z's Avatar
SS350Z
My 03 z also grinds when shifting into 6th if I skip shift. It doesn't grind when I run through all the gears carefully, only when I go from 3rd or 4th to 6th. Is this part of the recall? My car will be out of warranty soon, do you think I should try to get it fixed or replaced?
Old Aug 18, 2005 | 09:39 PM
Faizei's Avatar
Faizei
My 05 Z makes a chain griding noise that is comming from the passenger side only when shifting into 3rd or 4 gear. Have you guys heard of this problem? Shifting into 6th gear has no problems for me.
Old Aug 19, 2005 | 01:17 PM
ANXIOUZ's Avatar
ANXIOUZ
My 5-to-6 doesn't grind but I do have to almost pause to get it into 6th most times when going around 50mph. I might take it in to have them look. Oh, I have an 03.
Old Aug 19, 2005 | 04:29 PM
SS350Z's Avatar
SS350Z
Has anyone out there that had this problem had it fixed?
Just wondering if its worth it.
Old Aug 19, 2005 | 05:59 PM
spacemn_spiff
I dont have any grind, dont think I need a fix. I am going to change tranny oil just as a precaution.
Old Nov 3, 2005 | 07:55 PM
SS350Z's Avatar
SS350Z
Just an update. I took my z in to the dealer, and they decided to replace the tranny.
Old Nov 3, 2005 | 08:05 PM
Zmeflyby's Avatar
Zmeflyby
I just shift slower than normal into 6th gear. That takes away the grinding for me.
Old Nov 4, 2005 | 07:47 AM
fairladyinit's Avatar
fairladyinit
Yeah don't worry I doubt anythings wrong. I sometimes get the grinding noise going into third.
Old Nov 4, 2005 | 10:47 AM
jt14894's Avatar
jt14894
Mine did that for a very short period of time when it had just under 20,000 miles.
First, it did it between 2nd and 3rd then it went away.
Then, it did between 4th and 5th and then it went away.
The car has 31,400 miles now and it hasn't done it ever since.
Sometimes it does it, but thats because I'm a little too quick and catch myself shifting before fully pressing down the clutch.
A friend of mine has a 2003 G35 and he had his tranny replaced because it kept doing it between 5th and 6th.
I know there was a TSB on this because of an issue with the syncros being made of brass.
For those owners that have this problem, they would replace the entire tranny which contains improved syncros made of steel.
Old Nov 4, 2005 | 12:56 PM
Fletch69z's Avatar
Fletch69z
Yep, it's common so just get it checked out by the dealer.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Bigsyke
Sep 11, 2015 06:19 PM
