Dyno'd My Stock 2003 5AT Touring 350Z
Old Aug 20, 2005 | 10:40 AM
Stailey's Avatar
Stailey
Default Dyno'd My Stock 2003 5AT Touring 350Z
I went with a group of my friends (around 6 of us) and we all got our cars dyno'd.
I ended up with 243 hp and 194 ft/lb tq
Temp: 96
Humidity: 58
Pressure: 33.4
My Dyno Click Here
This is my first dyno ever... and I was really suprised at the number. I really thought I would get in the high 220's low 230's... but i am dissapointed in the torque... Dyno was SAE Corrected and I am running 93 Octane...
Tell me what you think, my car is stock... and i want to learn a little more about what may have happened here... both good and bad
Old Aug 20, 2005 | 10:44 AM
05 NISMO's Avatar
05 NISMO
is that right? 194 ft/lb tq, seem low.
Old Aug 20, 2005 | 11:33 AM
Stailey's Avatar
Stailey
bump...
Old Aug 20, 2005 | 12:00 PM
hypeiv's Avatar
hypeiv
i have seen dyno numbers all the over the place... I have lost faith in them. They seem to only be good for before and after a mod so you can see the gains as a percentage, or to compare two cars if they were dyno'ed back to back on the same day. There are too many variables that can screw up a dyno.
Old Aug 20, 2005 | 03:48 PM
arejohn's Avatar
arejohn
I can's see your chart, but if your max hp was around 6200rpm you had to have more than 194lb torque.
Old Aug 20, 2005 | 04:05 PM
Stailey's Avatar
Stailey
max hp came at 6414... anyone want to host the jpg. of the dyno chart for me?
Old Aug 20, 2005 | 04:11 PM
odarabla's Avatar
odarabla
Default Stock Dyno.
I have a 2004 Base Model 350z 6MT. All I have installed on the car is a injen cold air intake. My car's Dyno was 255 RWHP and 250 RWTQ at 6489 RPM. Was it a Mustang Dyno or a Dynojet Dyno that you used??
Temp: 96
Humidity: 58
Pressure: 33.4
My Dyno Click Here
Old Aug 20, 2005 | 05:52 PM
arejohn's Avatar
arejohn
Doing the math, I figure you had 199 torque at 6414 rpm.
Old Aug 20, 2005 | 10:09 PM
ajk4's Avatar
ajk4
i've heard that the torque converter in the 5at isnt all the way locked-up or isn't locked-up at a given point to give an accurate reading and so numbers on the tq can be higher or lower depending on the amount of lock-up inside the tranny. for instance here is my dyno in stock form with my '03 5at. i made a max of 277tq, but obviously thats way off considering drivetrain loss and the fact that it comes with 274tq stock.
Siqcology
Sep 18, 2019 01:45 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
FromGtoZ
Sep 20, 2015 03:41 PM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
RWDBajan
Sep 8, 2015 06:25 AM
