how do you disable vdc completly?
Old Aug 23, 2005 | 05:19 PM
EdgeOfSanity's Avatar
EdgeOfSanity
Default how do you disable vdc completly?
i know just pressing the vdc off button does not completly kill it. I've never seen anyone post about how to do it.
Old Aug 23, 2005 | 05:35 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
there is a box behind the shifter with a harness you much disconect
Old Aug 23, 2005 | 06:25 PM
EdgeOfSanity
so if i pulled off the center console panel it would be behind the shifter?
Old Aug 23, 2005 | 06:54 PM
The Mike's Avatar
The Mike
Isnt' there extra weight in mechanical parts that would become useless after you disconnect the vdc? Would it be wise to look for those and remove them as well?
Old Aug 23, 2005 | 06:57 PM
Jason@Performance
Performance Nissan
didnt hear it from me
From Drivers perspective it is closer to the driver then the shifter... just about rite under the ash tray...
you WILL have your VDC / SLIP light on all the time once this is unplugged...
you WILL have better steering response
you WILL have better throttle response
you WILL still have ABS
you WILL beable to spin the wheels and not have VDC kick back in...
Old Aug 23, 2005 | 07:02 PM
EdgeOfSanity
better steering and throttle at the cost of a light in the dash, hmm... i think i know what i'm doing tommorow!
Old Aug 23, 2005 | 07:03 PM
EdgeOfSanity
one last question, if i decide to reconnect the harness will that kill the light in the dash?
Old Aug 23, 2005 | 07:15 PM
Jason@Performance
Performance Nissan
yes
Old Aug 23, 2005 | 07:21 PM
Mantis3024's Avatar
Mantis3024
Will disconnecting it override the brake fuse? (would you be able to do standing burnouts without pulling the fuse?)
Old Aug 23, 2005 | 07:40 PM
EdgeOfSanity
i would think so since vdc is what makes it hard to to do without pulling that fuse.
Old Aug 23, 2005 | 07:45 PM
Jason@Performance
Performance Nissan
yes
Old Aug 23, 2005 | 07:49 PM
Jason@Performance
Performance Nissan
The above is done at the user's own risk. With this modification done the user understands that all traction control will be fully disabled while retaining use of the ABS System. Jason & or Performance NISSAN is not responsible for the User loosing control of the vehicle due to the absence of the VDC & TCS system.
Old Aug 23, 2005 | 07:53 PM
JP_WRX's Avatar
JP_WRX
If someone does this please post a pic of the harness/fuse for the rest of us, just to be foolproof. Thanks!
Old Aug 23, 2005 | 07:55 PM
Nano's Avatar
Nano
basically you turn your car into a base Z, right?
Old Aug 23, 2005 | 08:10 PM
Jason@Performance
Performance Nissan
if you could cut a hole under where your ash tray goes, you could do this without removing the console...
I guess so, I havent driven a Base enough to see if the steering has a sliiiiight delay in it...
Old Aug 23, 2005 | 09:43 PM
EdgeOfSanity
i'll do a how to of this tommorow, it should be pretty simple.
Old Aug 23, 2005 | 09:52 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
is this a bad idea since the VDC has saved my a$s before and also lost control with the VDC off....
Although I hear the car responds better for you rather than the car responding itself. The best motoring guys prefer the base over the other models
Old Aug 23, 2005 | 09:56 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
How would the steering have a delay?
The steering column goes directly to the steering gearbox pinion.
If the wheel is turned 45 degrees by the driver, the pinion is going to turn 45 degrees, the rack will then move accordingly. It's all mechanical from the hands to the end of the tie rods.
Chris
Old Aug 23, 2005 | 10:37 PM
Jason@Performance
Performance Nissan
it feels like it... i know what you are saying... but it just feels like it...
the car just feels overall more responsive...
maybe it just keeps the brakes from controlling the turn?
Old Aug 24, 2005 | 12:51 AM
Nominee's Avatar
Nominee
How is it not 'completely' killed? When I turn my VDC/TCS off, to my knowledge I can my spin my wheels as freely as I want.
