450z? WTF?
Old Aug 25, 2005 | 05:37 PM
  #41
Rosko's Avatar
Rosko
Originally Posted by Sisko99
The race versions of the 350 (those running in the Grand Am series) are sporting a V8...
Just curious. Where did you get this information? I've read about the Unitech Z running in Grand Am Cup, and it's a v6. I might add that it keeps up with 911's and routinely passes them by the way
I've heard someone is working on a 350z to run in Grand Am, Rolex, GT class. Maybe they're using the 4.5 V8 for that series. It seems like they could get the job done with the 6 banger, but anything's possible.
Specs on the Unitech Z racecar ....
http://www.performancenissanracing.com/car.html
Old Aug 25, 2005 | 06:04 PM
  #42
Nano's Avatar
Nano
engine swaps are not allowed in grandam as far as I know. And the modifications on stock engines are pretty limited as well...
7-8 Engine
7-8.1 Changes to the OEM engine management system are permitted so long as the standard OEM hardware is not changed or altered.
OEM engine speed limiting device may be disconnected.
Eligible 1996 or later OBD II equipped model cars may replace the OEM engine management system with a Motec M4/GAC or M48/GAC engine management unit. The Porsche GT3 Cup model is not eligible.
7-8.2 The following components may be tooled enough for balancing only - pistons, rods, crankshaft, harmonic balancer, flywheel and clutch.
7-8.3 The lightest rod and piston must remain unaltered.
7-8.4 The crankshaft, flywheel and harmonic balancer may weigh no less than the OEM specification.
7-8.5 Only OEM pistons may be used, first and second size OEM pistons are permitted.
7-8.6 The oil pan and oil pick up may be modified (not the pump)
7-8.7 Engine oil Accu-sump system and valve is permitted
7-8.8 All pushrod engines may use aftermarket blueprinted or adjustable length pushrods, provided they are of the same material and configuration of the original.
7-8.9 Other items that may be replaced include cam gears, sprockets and chains.
7-8.10 The airbox and air filter are free on normally aspirated cars. Ram air induction is not permitted.
Old Aug 25, 2005 | 06:35 PM
  #43
Electricchild's Avatar
Electricchild
Originally Posted by davidv
A 400Z or 450Z is always a possibility, but one of the drawbacks is weight distribution. The 350Z has about a front to rear weight distribution of 52 to 48 percent. Of course a bigger engine means added weight in front.
Apparently this thing will be lighter--- so maybe it will maintain the same weight distribution. We'll see...
Old Aug 25, 2005 | 07:24 PM
  #44
jinsei888's Avatar
jinsei888
I want one! What about a new Z with the QX INFINITI engine haha!
Old Aug 25, 2005 | 08:03 PM
  #45
PerfectOddz's Avatar
PerfectOddz
Originally Posted by sentry65
probably a GTR
Z's have always been V6
and RWD - not to say they can't change the formula, but who'd buy a GTR for $65k if you could buy pretty much the same car only badged as the Z for thousands of $ less?
Not to nitpick...well I guess this is nitpicking.
The old Z's were a straight 6.
Old Aug 26, 2005 | 01:13 AM
  #46
Rizlam's Avatar
Rizlam
This might be one of the many 'conjecture' articles that appeared in the autumn of 2004 when the first rumours of the GT4 version of the 350Z (launched in Europe) came out. As you might know, it was brought out in conjunction with the PS2 game Gran Turismo 4, but the rumour mill assumed it would be a GT-four in the Toyota sense; i.e. turbo'd and with all wheel drive. When it was launched in March this year, obviously that was not the case.
But I also found rumours of a 450Z on a Russian site dating back to September 2003 so it's anyone's guess ... !
Old Aug 26, 2005 | 04:56 AM
  #47
dcmidnight's Avatar
dcmidnight
Originally Posted by Kaitain
You guys have it totally wrong what it says is:
"We surrender."
Just more drawn out.
ROTFLMFAO
Old Aug 26, 2005 | 06:14 AM
  #48
spacemn_spiff's Avatar
spacemn_spiff
Originally Posted by Nano
Even Honda most glorious engines (formula 1 1000hp/liter) used forced induction.
Are you talking about honda engines before 89, I dont if Honda was in F1 then. Formula1 went to normally aspirated engines in 89. So there are no forced induction engines anymore.
Old Aug 26, 2005 | 07:33 AM
  #49
Rizlam's Avatar
Rizlam
Oh yes
Williams Honda - 1984 to name but one year - with Turbo
Old Aug 26, 2005 | 09:34 AM
  #50
Nano's Avatar
Nano
Originally Posted by Rizlam
Oh yes
I was thinking more of...
1986 Williams-Honda turbo... world champions
1987 Williams-Honda turbo... world champions
1988 Mclaren-Honda turbo... world champions
(note that honda then went on to win 1989, 1990 and 1991 with NA engines).
Before boost limitations were introduced(1988) Honda engine produced close to 1500bhp at ~75 pounds of boost in qualifying trim from a 1.5Liter engine. in 1988 Honda won 15-16 races, and if not by a silly mistake by Senna during last lap at monza, it would have won 16-16 races... Most dominant car in F1 history.
Old Aug 26, 2005 | 01:26 PM
  #51
Mr_Q's Avatar
Mr_Q
My guess is this could be real.
They release the new Skyline in the USA as an Infinity.
So
Release the 450z as the upscale model Z or even new Z. Strip off most the expensive gadgets from the skyline to keep price down. De-Tune, etc. Wham, 450z.
Old Aug 26, 2005 | 05:54 PM
  #52
spacemn_spiff
Right now F1 NA 3.0 liter engines produce about 1000Hp and redline at 19000rpms. Those are crazy numbers. 333Hp/liter. Loads or stresses on the engine increase the square of the increase in rpm. 6K redline compared to 18k redline equates to 9 times the load and thats not taking into effect the mechanical advantage, moments etc. Anyway, after all that engines weigh only around 100kgs/220lbs. Love F1, especially the whine of the engines.
Old Aug 26, 2005 | 06:05 PM
  #53
southern_info's Avatar
southern_info
In a way I'm mad about the 450z and in a way I'm happy. I'm mad that nissan didn't come out with it earlier if that is the case it's going to drop on the u.s. market and it is going to cost alot more then any other nissan badge car. Then I'm happy to see the Z getting what it deserves more power. That's what I've been desiring since owning my Z after getting use to the power and losing to cars that looks like they should be chump type cars. The Z is just plain sexy and has it's own exotic sex appeal. Now there's a motor going to be in it with an attitude and imagine F/I'n a V8 Z will be just freaking awesome.
Old Aug 26, 2005 | 06:12 PM
  #54
roark's Avatar
roark
Then get out your VCR/TIVO and tape away, since next year we'll be listening to 2.4 litre V8s across the board (mostly.) I'll really miss the scream of those V10s through the tunnel at Monaco. Oh well, all good things must come to an end.....
  #55
Clapton9286's Avatar
Clapton9286
The 6 adds character. As COOL as an 8 would be, thats simply not the Z.
Old Aug 26, 2005 | 07:01 PM
  #56
Mr_Q's Avatar
Mr_Q
well thats why it should just use a single turbo and stay a 6. Zs are always a 6....always.
Leave the twin turbo setup for the more expensive Infinity Skyline!
Old Aug 26, 2005 | 10:42 PM
  #57
bamyi's Avatar
bamyi
I don't trust anything the french says.
Rev_Night
Nov 7, 2020 06:00 PM
350z_z33.
Jul 3, 2017 04:01 AM
cashmoney03
Sep 27, 2015 05:24 PM
Black70Stang
Feb 7, 2003 07:03 PM
abz123
Oct 29, 2002 08:21 PM
