Z on Ethanol??
Old Aug 27, 2005 | 08:12 PM
the7ferret's Avatar
the7ferret
Default Z on Ethanol??
Will/Could the Z run on Ethanol?
The Titan already can, would it be as simple as a ECU upgrade?
It is supposidly 105 octane?
Cheaper, Cleaner, Renewable, and dosent require the use of the army, just butt loads of farmers.
http://www.e85fuel.com/index.php
http://www.eere.energy.gov/cleanciti...s/ethanol.html
Old Aug 27, 2005 | 11:29 PM
Mr_Q's Avatar
Mr_Q
Any car that can take normal unleaded gas can run on ethanol. It will take a tank or two for the computer to adjust but it won't harm it.
You will get less HP though. And will have to go through another tank or two of the normal stuff when you switch back.
I lived in N.Dakota for 2 yrs and most stations their use ethanol. The cars run fine.
Old Aug 28, 2005 | 05:54 AM
tropicalypso's Avatar
tropicalypso
interesting, I didn't know that
Old Aug 28, 2005 | 07:44 AM
babbagandu's Avatar
babbagandu
why would u lose hp if it has higher octane?
Old Aug 28, 2005 | 07:56 AM
An octane rating of 105 is a bit of a overkill for the 350Z stock, but you should be fine as is.
Old Aug 28, 2005 | 07:57 AM
THT's Avatar
THT
If you'll recall back to high school chemistry, when you compress a gas, it becomes more volatile and combusts at lower temperatures. This is important because the more your compress the A/F mixture in the firing chamber, the easier it is for the radiant heat from the engine block to detonate the mixture. This is problematic because it drives the piston down before it (and the crankshaft) are ready. This is knock.
Premium gas is of a higher octane than regular gas. Contrary to popular belief, higher octane does not always result in better performance (from a horsepower standpoint). Octane retards ignition so higher octane fuels require more heat to detonate, thereby lowering the chances of predetonation. That's why people who are running nitrous oxide or forced induction run 93+ octane fuel.
Too high of an octane without the need will cause the air/fuel mixture to not burn completely/properly resulting in less power produced.
Old Aug 28, 2005 | 08:03 AM
Don't think so. The octane rating is the fuel’s ability to avoid pre-detonation. If your car runs well on 91 octane gas, then it will run well on 105. The same may not be true of 87 rated gas.
Old Aug 28, 2005 | 10:48 AM
the7ferret's Avatar
the7ferret
http://www.e85fuel.com/pdf/e85_technical_booklet.pdf
ON this document by the DOE Page 9 the chart states that pure methanol, and ethanol gives a 5% boost in power compared to reg gas. and e-85 is 3-5% boost in power.
Old Aug 28, 2005 | 11:27 AM
kwkslvr's Avatar
kwkslvr
why don't you here about more people using ethanol then? what are the downsides?
Old Aug 28, 2005 | 12:54 PM
plumpzz's Avatar
plumpzz
cost... warranties on cars... uhmm probably other little stuff the oil companies are trying to suppress -.- bastards..
Old Aug 28, 2005 | 02:10 PM
JCat's Avatar
JCat
Despite that Ford said that my 1978 Fiesta would run fine on ethanol, both times I purchased it, my fuel pump failed.
Be very careful.
Reid@SP
Product Announcements
19
May 31, 2010 10:00 PM
polar
May 13, 2006 01:36 PM
