Question about VDC and the Slip light
Yeah if you pull that fuse I think ABS goes with it, and thats not something you should sacrifice. Ive heard of some fuse mod though, do a search you may be able to find someone who has been able to ONLY disable vdc.
Originally Posted by BlackSpec02
interesting i didn't know about that... will that always be true if you have a slightly wider tire, even of the same series.... i.e. a 40 series tire? (so they would be wider and taller technically?)
what does 91W or 96W mean?
The rear tires are 245/45 and the sidewall height is 45 percent of 245 mm or 110.25.
91: load index
W: speed rating
Originally Posted by n3m3s1s
I searched a little bit on this issue and found a little bit of info but thought I would ask in a new thread. I bought a used 03 Touring model with about 27k on it. It has VDC as I see the button to turn it off. I dont drive to wild at all but when I have noticed the slip light coming on the most was when I was getting onto the freeway on a downhill slooped on ramp and let off the gas a tad and then I feel/hear a change in the car. I read in the book about it and is it putting on the breaks or cutting engine power or both. I am really juut wondering if it is really that sensitive than when acclerating down an on ramp and I slighty lift that it freaks out and throws up the slip light. Also just want to make sure that there is nothing potentialy wrong with the car. Thanks for any help guys.
It sounds like the VDC saved you from a fishtail/spinout. If you accelerate in a turn and then lift in a RWD, you get a effect similar to pulling the hand brake. What you described is a technique used to get the car into a drift.
Be careful, that car is faster than it seem and trouble can come at you pretty quick !
^ thats what I said! lol.
Good info, I didnt realize the side height was a percentage of the width. Where does the load index come from and what does it mean?
Originally Posted by davidv
Yes. It will always be true. 225/45 is the sidewall height, or 45 percent of 225 mm or 101.25 mm.
91: load index
W: speed rating
91: load index
W: speed rating
Vigman
Nov 17, 2015 04:34 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
