So 300hp track engine or 287hp engine, which one takes to mods better?
So guys which engine takes to mods better? The track/06 engine, or the pre 06 287hp engine? Is it better to mod one over the other? Im still trying to decide if buying a used 04/05 350z would be worth it(other than saving money) over a new 06. Money is a little tight for me but If its worth stretching the budget for a little while I will.
Also no one has an official SC kit out for the 300 HP engine yet. ProCharger has one that might be available at the end of this year but everyone else won't be sometime until next year.
Well mod for mod the 300hp engine will respond better because of its stronger internals. I say the 05 track is the best car to mod. If you get an 06 u can mod it but just keep in mind the 03-05's weigh alot less than the 06.
my friend at Turbo Mag was planning on doing a test article on my new ride. but he told me the '06's come with a new ECU, making it more difficult to modify the car. if the ECU senses any change in fuel/air, it will conpensate or something like that. unless ur planning on changing the ECU, itll be a hardache for those mod shops to juice any HP. hopefully my friend can still write something up on Turbo.
sorta makes me wonder if i shouldve gotten a used Z. i couldnt find any new '05's in southern cali, but being stuck with an '06 is fine with me.
Originally Posted by thawk408
Don't worry, the 06 ECU is probably like the 05 ECU. The 05 ECU likes to dump abunch of fuel even with mods. With all my mods I am still running way rich. The solution is to get a reflash or a Greddy Emanage Ultimate or some other form of a piggyback.
Originally Posted by roark
You have intake cam timing. The Rev-UP motor adds variable timing to the exhaust cams.
Could somebody please explain the difference, I went to howstuffworks.com and seen nothing. Kind of interested for my own knowledge.
interesting, I thought the 287 motor with NVCS also had variable exhaust cam timing. Learn something new every day.
As for the ECU compensating.....it's something Nissan does on the lower model cars, making them super extra clean, to give them some leeway on the performance models......the ecu uses the 02 sensors hardcore to keep a nearly perfect 14.7:1 afr at all throttle levels EXCEPT wide open......to maintain maximum efficiency and clean emissions. My turbo 01 Sentra was like that...I've had an Innovate LM-1 wideband on it for about 2 years now.....the only way I could really alter how my fuel was at idle and normal driivng was to just plain disconnect the sensors, haha!
anyways, it wouldn't surprise me if Nissan did that just because of stricter emissions laws or something.
Guest
Posts: n/a
can someone with knowledge and the time please make me a fact list on the 2 engines. including 03-04 Z's 05 track and 35Z and 06 Z's
please include all factors such as weight changes to the engine and all other items related to the differences
im gonna make it a sticky so i dont keep getting these "which one is better" posts
everyone please feel free to contribute the pros and cons of both. here is the tricky part..... please keep the info as objective as possible
just post it here and ill copy and paste it into a new sticky thread
thanks
thanks
