waiting is the hardest part....
Old 10-28-2005, 06:19 PM
Vamos_Rafael
Vamos_Rafael's Avatar
Originally Posted by ROGUELITE
i would think this is true with any car stacking solid hp/torque if you don't know
what you are doing. i always make it a habit when driving a new car to test the
limits thoroughly. the limits of the car and the limits of the tires. in general you
need to find the breaking point of your tires under certain conditions and just
what kind of maneuverability is achievable with your setup. i would say the Z
can be a beast in terms of torque and weight. it's your job to tame it.
when i first got my Z I decided to open it up one day and nailed it in left turn in
an intersection and i could feel the rear swing wide but i was able to correct it.
one thing you should do if you haven't is learn about throttle steering, etc. in
terms of what happens to momentum as you brake and accelerate. it's a very
important technique to learn.
the key is to take it slow and learn your car. otherwise you will be posting the
day after getting it from the dealer that its wrapped around someone's tree.
First RWD car is always hard!
Old 10-28-2005, 07:34 PM
ASTIG_Z
ASTIG_Z's Avatar
Tell me about it, I spun out cause of a turn....but i was redlining shifting to 2nd....what a moron huh. I am at least very careful now...
Old 10-28-2005, 09:47 PM
ROGUELITE
the Zbler eLf
ROGUELITE's Avatar
haha. so true. i had a miata as my first rwd car and i thought i could handle the
thing. decided to take a curve hard and throttled up. threw my car across the
road and slid into a ditch at 1 in the morning. was moving so fast even got grass
stuck between the wheel and tires! and yes, four flat spotted tires! an expensive
lesson but one i never forgot.
07ZEKE
08-23-2021 09:15 PM
04-22-2021 09:42 PM
ablaine
11-29-2016 10:13 AM
HoBrahYouStink
06-24-2016 10:58 PM
Fixxxercask
Cooling System
11-05-2015 03:21 AM
Quick Reply: waiting is the hardest part....
