what's the recommended tire pressure?
Old Nov 1, 2005 | 04:35 PM
Si_2_350Z's Avatar
Si_2_350Z
Question what's the recommended tire pressure?
Can someone tell me what's the recommended tire pressure should be? My front is off by 2psi, should I bother to put air? And when your looking at the tire pressure, is the top number for right or left?
Thanks
Old Nov 1, 2005 | 04:36 PM
cessna's Avatar
cessna
Should be indicated on the inner door post....
For the G it the Drivers rear door...
Hope that helps.
Old Nov 1, 2005 | 06:24 PM
Si_2_350Z's Avatar
Si_2_350Z
Hope that helps.
cool thx. Any one know about the tire pressure indicator, if the top number is left or right?
Old Nov 1, 2005 | 06:37 PM
DavesZ#3's Avatar
DavesZ#3
Apparently the factory wasn't consistent with top/bottom/left/right convention. Some people report top=left others see top=right. Left about 5psi out of one then drive it around and see which one is which. BTW, on mine top is right.
Old Nov 1, 2005 | 11:39 PM
zpak's Avatar
zpak
+1.
Mine's top = right.
Manual says never to trust or rely on the electronic reading. Always double check with an actual pressure gauge, cold.
Old Nov 2, 2005 | 02:36 AM
ZRA's Avatar
ZRA
35 pounds all around on cold tires. Mine is top right.
Old Nov 2, 2005 | 05:01 AM
Category5's Avatar
Category5
Default Subtle
There should be a ">" symbol indicating which number is left/right.
Old Nov 2, 2005 | 05:32 AM
Vamos_Rafael's Avatar
Vamos_Rafael
somehow i think mine is top left :/
some how i lost my tire pressure cap thing on my left rear wheel and it shows on the gauge... that top is less than bottom about 1-2 psi depending on wtf ...
Old Nov 2, 2005 | 05:54 AM
tmounk's Avatar
tmounk
The psi gauge in the car is all screwed up, but it does tell you when your low with load warning beeps.
Old Nov 2, 2005 | 04:28 PM
Si_2_350Z's Avatar
Si_2_350Z
damn, this site is so useful. Thank you all for your response.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
