newbie need help !!
Old Nov 3, 2005 | 09:44 AM
z_a1213f's Avatar
z_a1213f
Default newbie need help !!
i own z 03 i just bought this baby 2 months ago. and the warning sign for low gas is on all the time evetough the gas is full. is that the way it is suppose to? also the carpet underneat the driver seat is wet everytime its raining. have anyone experience this? sorry if it's a stupid question..thank you
Old Nov 3, 2005 | 09:49 AM
Vamos_Rafael's Avatar
Vamos_Rafael
go to a dealer and check out the gas thing?
Old Nov 3, 2005 | 09:50 AM
Welcome
and the warning sign for low gas is on all the time eve tough the gas is full. is that the way it is suppose to? – No. The “low fuel” light should come ON when the fuel is…ummm…low.
also the carpet underneath the driver seat is wet every time its raining – This is a serious problem. Water inside the car will soak the carpet, and eventually rust the floor. Have the leak checked by a competent shop.
Old Nov 3, 2005 | 09:51 AM
Vamos_Rafael
yeah basically goto a nissan dealer to check out those problems ^.^
Old Nov 3, 2005 | 09:54 AM
cessna's Avatar
cessna
Congrats on your new purchase....
As for the wet floor mats I've had the same issue with my suby 2.5RS and on both VW's I used to own...
In those cases, there were drain plugs missing.... Might be a simple problem... get it looked at fast, as water=corrosion
Badmonkey's Avatar
Badmonkey
I am not positive on this, but the fuel pump assembly, which is located behind the passenger seat, has a lever attached, which is the fuel indicating sender. This might have a switch attached that would send the signal to the dash panel. If you are not too much of a do-it-yourselfer, then I would take it to the dealer. The rain issue might be a seal which goes around your wiring harness to the ecu. If you take off the plastic covers by the battery, you can see a round rubber grommet-type cover. You have to remove all the black plastic parts, not just the battery cover. This grommet snaps into the body, if it has come loose or the plastic holders have broken off, it will leak into the passenger floor area. This is pretty serious,because your ecu and main wiring harness are all there. If these get wet, you could be in for some big troubles.
Old Nov 3, 2005 | 12:52 PM
tonystark's Avatar
tonystark
I got my car used too dude. It is a 2003 and it only had 25,000 miles on it. I got mine from carmax and I have not had the problems that you have. Sorry to hear this man. Hope that you get it fixed *thumbsup*
Old Nov 4, 2005 | 10:26 AM
z_a1213f's Avatar
z_a1213f
thx guys for the info. i'll take it to the dealer asap
Old Nov 4, 2005 | 10:28 AM
siua's Avatar
siua
welcome fellow z.. take it to a nissan dealer..asap...
Old Nov 4, 2005 | 12:10 PM
Fletch69z's Avatar
Fletch69z
If you're under warranty definitely get it into the dealer quick because those sound like problems you should get fixed for sure. Welcome to the site by the way!
Old Nov 4, 2005 | 12:12 PM
jasonbokamper's Avatar
jasonbokamper
Regarding the fuel issue, I had the same issue for the past few months. The dealer confirmed the fuel sending unit was bad and replaced it yesterday.
All is well now.
JB
Old Nov 4, 2005 | 04:06 PM
LATEZ's Avatar
LATEZ
I'm guessing that this car may have been repaired from an accident... water inside the cab is pretty serious..... mos def have someone look at it
ricks350z
Dec 5, 2012 03:51 PM
EnthuZiast
Sep 7, 2003 02:51 PM
mdrobe2
Jul 14, 2003 07:41 AM
afr0puff
Jul 9, 2003 03:31 PM
lauderdale75
Jan 9, 2003 06:23 PM
