shifting
Old Nov 8, 2005 | 08:08 PM
Escobar's Avatar
Escobar
Question shifting
Hey, I herd if you skip gears while you shift, for example 1st to 3rd or 4th to 6th, it will throw off the synchronization of your transmission?? Sounds like crap to me. Is that true because sometimes i see no reason to shift into some gears occasionally.
Old Nov 8, 2005 | 08:28 PM
Aggro_Al's Avatar
Aggro_Al
It's BS. But, Rev-matching is your friend when doing this.
Old Nov 8, 2005 | 08:39 PM
MagicPie's Avatar
MagicPie
When shifting up --say from 1 to 3 I hold the clutch in longer then normal to let the rpms fall so to match the rpm to the speed of 3rd gear. when shifting down from 4th to 2nd then I will clutch in and give the throttle a blip to increase the revs to match the speed to 2nd doing that everything is safe and smooth.
Old Nov 9, 2005 | 07:15 AM
Originally Posted by Escobar
Hey, I herd if you skip gears while you shift, for example 1st to 3rd or 4th to 6th, it will throw off the synchronization of your transmission?? .
Can you give a reference for this statement?
Old Nov 9, 2005 | 09:30 AM
highside107's Avatar
highside107
+1, good point about holding the clutch in longer to let the rpms fall more.
Old Nov 9, 2005 | 10:03 AM
Escobar's Avatar
Escobar
Yeah, thats what i thought. I allways double clutch so its all good
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
seagrasser
Oct 11, 2015 03:27 PM
apex locator
Oct 6, 2015 05:58 PM
