GL4 & GL5 ????
Old Nov 26, 2005 | 03:09 PM
soldierboy's Avatar
soldierboy
Default GL4 & GL5 ????
I am going to change the trans & diff oil for my Z... here is the conflict.. I am looking at M1 and Royal Purple.. they come with 75w90. according to the label this is good for diff and trans. Also it meets the require for gl4 and gl5. so can i use the same oil for diff and trans????????????????
Old Nov 26, 2005 | 07:11 PM
Tekwon-V's Avatar
Tekwon-V
no GL-5 in the transmission; GL-4 only.
GL-5 in the rear differential is ok.
check out the repair forum on this issue. there are numerous discussions on it.
i used the redline MT90 in the transmission and mobil1 gear lube in the differential.
Old Nov 27, 2005 | 07:32 AM
johnlotusboy's Avatar
johnlotusboy
If you care about tranny warranty, use the factory synthetic oil, it is a 75/85.
Nissan will void warranty if other oil is found in transmission.
Old Nov 28, 2005 | 09:00 AM
Z'd's Avatar
Z'd
As long as you can document that your choice of lube meets the API specs in the owner's manual (GL-4 and GL-5, as specified for each application), they can't void your warranty.
If they require you to use their specific lube during the warranty period, they have to provide it free of charge- don't know about you, but my dealer didn't volunteer to do that...
gearhead350
Jul 26, 2015 04:57 PM
GreenGoblin
Oct 7, 2010 07:00 PM
Spec_Tacular
Aug 27, 2007 12:23 PM
Fluid1
Feb 22, 2007 10:30 PM
MagicPie
Dec 12, 2005 07:12 PM
