Tire Pressure Alert
Old Nov 27, 2005 | 09:22 AM
zdan's Avatar
zdan
Default Tire Pressure Alert
Not sure if it's a flaw in the sensor, bad tires or just me, but the tire pressure sensor on my new Z sounds off way too often. When the air tempature drops it's almost a given that it will sound off. I understand that air contracts when it cools, but this is ridiculous. My wifes car has the sam feature, and it never trips. Is it the low profile tires, bad design or should I take it to the dealer only to have them add air until the light goes out. It appears to trigger even with a 1lb difference. Please advise.
Old Nov 27, 2005 | 09:37 AM
Soccerprep205's Avatar
Soccerprep205
HAHAHAH YES!!! i was just about to make this thread... i get a loud BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEP and it flashes PSI at me.... whenever its cold.... and my CEL comes on... it just started when it got cold...
Old Nov 27, 2005 | 10:05 AM
zdan's Avatar
zdan
Default Air Pressure alert
The Beeep is part of the alert, at least thats what the book says. My issue is that if a 1 to 2 lb fluctuation is causing it, thats bad. After I drive for a little while and the tires warm up, the pressure returns, and sometimes the light will go away. The manual really does not explain this feature very well, including how to tell if it's the right or left tire. The little arrow on the computer is not correct and it does not explain how to reset it other than adding air. I have 19" chrome rims with Bridgstone Potenza's
Old Nov 27, 2005 | 10:23 AM
Soccerprep205
oh hmm im on stock tires... i dont know whats wrong, oh well i'll wait till the warmer season!!!!
Old Nov 27, 2005 | 10:34 AM
DavesZ#3's Avatar
DavesZ#3
How much pressure do you actually have in your tires? My guess is that you only have 30 psi. Once the temperature drops, the pressure drops below 28psi and that triggers the warning.
Old Nov 27, 2005 | 10:45 AM
bstansbu's Avatar
bstansbu
Yep, I concurr. Hope that is your issue as that is an easy fix. Just put 35psi in all 4 tires early in the morning before driving. BEN
Old Nov 27, 2005 | 12:59 PM
ZZ33bOI's Avatar
ZZ33bOI
yeah i have the same problem! but after i switch my rims i didnt add the TPS so i dont even have the TPS gauge workin its showin blank lol
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
