clutch chattering/winding noise?? HELP
Old Nov 27, 2005 | 04:19 PM
ep3turbo's Avatar
ep3turbo
Default clutch chattering/winding noise?? HELP
is mine the only z that when the clutch is not pressed it makes a faint noise like a clutch chatter and when i push it in it stops??? and also when i drive slow like in 1st and 2nd gear it makes a winding sound.. is this normal? is it covered under powertrain warrenty and what do you think it is? thanks..ADAM
Old Nov 27, 2005 | 04:24 PM
thezedsled's Avatar
thezedsled
Hey ep3... Not to be a killjoy but this has been discussed multiple times. Just do a quick search and you will find the info you are looking for. The slight chatter that you hear when the car is not in gear and the clutch is out seems to be normal. Mine does it and several other Z's that I have checked out do it too.
Old Nov 28, 2005 | 06:34 AM
Lexquiles's Avatar
Lexquiles
It is anoying but Normal
Old Nov 28, 2005 | 07:37 AM
VO...'s Avatar
VO...
Administrator
Winding noise = normal.
Chatter = need more description.
Old Nov 28, 2005 | 10:33 AM
halitosis's Avatar
halitosis
Winding noise = your burly synchros
Chatter = the dual-mass flywheel. Both are normal. Enjoy!
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
