techniques for driving in rain
Old Dec 6, 2005 | 04:53 PM
absoluturq's Avatar
absoluturq
i dont drive, but from a noob, u might wanna drive in higher gears, so u dont have so much torque
Old Dec 6, 2005 | 07:28 PM
imseksy's Avatar
imseksy
just dont drive in the rain... drive the Z hard always, but only in dry roads!!! =)
Old Dec 7, 2005 | 12:10 AM
hitop's Avatar
hitop
dude slow down before you hurt someone and then go take some driving lessons, don't mean to sound like a dick, but a Z ain't no camry.
Old Dec 7, 2005 | 08:16 AM
ROGUELITE's Avatar
ROGUELITE
the Zbler eLf
if you can't get driving lessons then an empty parking lot is your best friend in
bad weather. setup some cones or other soft markers and practice cornering
under different amounts of throttle. feel the car out and learn to read it under
different conditions.
cars speak to you all the time when you are driving but you just have to
understand what they are saying... learn the basics of throttle steering
which can really get you out of a jam if you do actually enter a turn too
fast or start sliding. learning to shift the momentum of a RWD is critical.
Old Dec 7, 2005 | 08:25 AM
halitosis's Avatar
halitosis
dude the chick on your avatar looks like an alien. who is that?
Old Dec 7, 2005 | 08:41 AM
ROGUELITE's Avatar
ROGUELITE
the Zbler eLf
LMAO.
Nah that's Tila Nguyen. www.tilashotspot.com
Old Dec 13, 2005 | 10:08 AM
JoeyFyed's Avatar
JoeyFyed
Thanks guys =]. gonna hit up my dads wharehouse parking lot when it rains =]
Old Dec 13, 2005 | 10:15 AM
Vamos_Rafael's Avatar
Vamos_Rafael
why dont u just go slower...
much easier and less pain than all that practice ****
Old Dec 13, 2005 | 10:25 AM
Silkk's Avatar
Silkk
I know you joked about it, but I'd suggest taking TCS off and practicing driving the car in the rain in a parking lot somewhere...
Learn its limits.
Learn how to bring it back when it slides out.
Driving the Z in the rain can be very touchy, if not borderline treacherous if you aren't careful. A little parking lot playing around will help a lot. Haven't used TCS in months and never plan on using it again... works against you more than it helps IMO.
As far as the back end sliding around a low speed, wet corner like that. Keep it lower in the RPM range, if you start to slide DO NOT BRAKE... If you do beging to slide, I usually shift to the next gear quickly (drop RPMs) and hit the gas (but not too hard), and it will grip and correct itself. Again, this will become very comfortable if you do a little practice...
Old Dec 13, 2005 | 10:28 AM
mavtais's Avatar
mavtais
If you never prepare for the worst, then the worst will be catastrophic.
Go for it, Joe!
when shifting in a corner, make sure you let go of your clutch when the rpm matches, that way you don't over torque the wheels. Also, don't let the needle drop all the way down to idle and then let go of the clutch because that will make you shift-lock. The concept is to keep your engine speed (RPM) and your transmission speed the same. When you get this right, you will have buttery smooth clutch releases. mmm... butter.
Old Dec 13, 2005 | 11:29 AM
thekinn's Avatar
thekinn
I think I've seen a few driving tip posts here.. and I appreciate all of the input. I should have my new Z in a month and always look for good advice.
Thanks for the replies (even though this wasn't my post)
Old Dec 13, 2005 | 11:32 AM
jinsei888's Avatar
jinsei888
just floor it and hope u make it haha
Old Dec 13, 2005 | 11:46 AM
halitosis's Avatar
halitosis
Downshifting when you are losing traction in the rear will only lead to more oversteering. Yes, silkk mentions stepping on the gas afterwards, but by then it will be too late. Downshifting (like the clutch-kick technique) is another form of inducing a drift and not recommended if you haven't mastered the drift.
Silkk, I beg to differ and you are way off in your suggestion of downshifting.
Old Dec 13, 2005 | 11:48 AM
halitosis's Avatar
halitosis
jvanquish why don't you stop post-whoring and post some content of value. This is not a race to see who has the most posts.
Old Dec 15, 2005 | 01:09 PM
tienlo's Avatar
tienlo
pretend you're driving a camry
Old Dec 15, 2005 | 09:26 PM
I’ve driven in the rain at Summit Point, WV with OEM tires. The tires are fine, you just have to alter your technique. The turn-in point and apex of a turn are different then on dry pavement. If you've driven with a professional in the rain on OEM tires, you'd be amazed how well the 350Z handles.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
Mattg350z
Oct 2, 2015 06:51 AM
