q about Brakes
How do u know when to change ur brake pads?
when it starts making noise when braking, is that it.....?
and i heard something about not changing ur brakes in time can mess up ur disks? thanx.
You should hear a squeeling, or if you take of your wheels you should be able to look at the pad and see how much is left on it. If you go too far past the squeeling you will end up eating your rotors, which yeah will cost you bank. some places will do a free brake inspection with an oil change, but i think places will tell you that you need brakes just to eat your money. check the thread on changing brake pads, once you do it once it will be easy.
Will this “mess up” the rotors? No not exactly. The rotors are designed to worn by the brake pads. On the other hand, they are not meant to be abused by metal-to-metal contact (no pad remaining).
