3.3 nonlsd to 3.5 lsd does speedo change
hey guys,i did a few searches but cant get a difinitive answer,i switched from a 3.3 non lsd from 5at coupe to a 3.5lsd from 6mt.does the speedo change and does anyone now how much.thanks
I'm def not an expert on this, and I'm assuming that those who have done the gear change would know for sure (and not just assume that the computer will correct it). but in mustangs you do have to buy and install a different plastic gear for the speedo to read correctly after you change the rear gearing. someone who can explain if/how the Z corrects this should chime in.
i speedo measures a vehicle's wheel speed. changing your rear end ratio doesn't affect the speed at which your wheels are turning. only changes the engine rpm for a given veh speed. to find out the change in engine speed just multiply by the ratio of the axle ratios. 3.5/3.3
Our 350Z's measure their speed with the ABS/TCS sensors which are located on the stub axels of the rear axel. Since the measurement is taken AFTER the rear axle, unlike Rustangs, the speedo is unaffected. Different tire diameters WILL change the speedo reading.
