Need some Help in releasing the shift knob !
Old Jan 8, 2006 | 10:12 PM
rennovatio's Avatar
rennovatio
Thumbs down Need some Help in releasing the shift **** !
Hello, i had posted this thread last time and i got some reply, so i tried to release the original shift ****, but i failed because i didn't see any trigger or screw underneath the plastic cover. Can someone please help me out ?
Thanks & appreciate
Old Jan 8, 2006 | 10:15 PM
Z BOY's Avatar
Z BOY
do a search. much has been written.
Old Jan 8, 2006 | 10:20 PM
Z MANIA's Avatar
Z MANIA
psychedelic one
search "How-To Shift **** for 5AT" You should find what you need there.
Old Jan 8, 2006 | 10:53 PM
rennovatio's Avatar
rennovatio
by the way, mine's a 6 speed manual tranny
Old Jan 8, 2006 | 10:56 PM
35oZephyR's Avatar
35oZephyR
Use a towel and some Vise grips...
Vise on shifter....another clamp on the **** but wrapped with a towel so it won't ruin your stock ****.
Make sure both ends are stable so you don't twist the actual shifter too much. Vise grip the shifter shaft with the boot lifted off so you don't actually ruin the boot.
**** should pop off once that thread seal breaks.
Trust me, it won't feel like it will go, but once it gives away you're home free.
Old Jan 8, 2006 | 11:01 PM
Z_Driver's Avatar
Z_Driver
Master
I used a soft terry towel and cresent wrench adjusted tightly. It won't dig into the leather. Done this 5-10 times. Shift **** still looks like new and I have had to crank on it a few times. Those ***** are on there tight. When they let go with the factory locktite ....man. This requires some good even pressure to twist them off.
Old Jan 8, 2006 | 11:14 PM
Z BOY's Avatar
Z BOY
strap wrench is best.
Old Jan 8, 2006 | 11:33 PM
Z_Driver's Avatar
Z_Driver
Master
You can get enough on it with a strap wrench? Humm ..... Good idea.
Old Jan 9, 2006 | 10:32 PM
thezedsled's Avatar
thezedsled
Same here, worked good...
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
