somethings wrong..
Old Jan 18, 2006 | 07:48 AM
breed's Avatar
breed
Default somethings wrong..
yesterday i was driving home and a light came on.. not sure what light it is cause i dont have a manual.it looks like a clutch pedal with two arrows..
the light was also followed by a long beep noise.now my clutch pedal is real spongy and stiff??? also my psi light is flashing??
Old Jan 18, 2006 | 07:58 AM
barthelb's Avatar
barthelb
Master
That was your TPS, Tire pressure Monitoring System. Check your tire pressure you'll find one is low. If you changed rims recently, after about 30 miles of driving you'll notice the same light.
Old Jan 18, 2006 | 08:18 AM
FlorendoCruz's Avatar
FlorendoCruz
u live in Ny... its jus freazing out and ur tire pressure drops. It;ll go away after u drive it around or gets warmer. Or u can jus put some air, 38-42 on stock tires.
Old Jan 18, 2006 | 08:46 AM
FireStormTT's Avatar
FireStormTT
Same light came on for me the other day when it was really cold in the morning. I don't have a manual either, but since the psi light was blinking, commom sense told me to put air in the tires. I did and the light hasn't come back...no problems.
Old Jan 18, 2006 | 08:58 AM
UBERMENSCH's Avatar
UBERMENSCH
Rule of thumb, dont' buy a car (from a dealer) unless they give you a manual.
Old Jan 18, 2006 | 09:01 AM
VO...'s Avatar
VO...
Administrator
It is the APS light. It is designed to light up if the tire pressure drops to 29psi or below. There can also be a malfunction too. My light will normally trigger when I take trips that take longer than an hour of drive time. After I stop and shut off the vehicle, it'll clear up.
Old Jan 18, 2006 | 12:00 PM
lax91181's Avatar
lax91181
you can download the manual from nissan's website, fyi
Old Jan 18, 2006 | 12:39 PM
r26's Avatar
r26
can something be spongy and stiff at the same time?
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
