Holding the VDC switch down???
Old Jan 22, 2006 | 03:50 PM
ericjackson's Avatar
ericjackson
Originally Posted by Jason@Performance
no you do not hold the button down...
i cant say how to do it... but I will give a hint... it was posted before in a thread I was writing in and I had someone else write how... I cant say exactly because of liability reasons...
The center console needs to be removed...
there is a box between the shifter and where the coin box would be...
pull out the plug...
is that the one that controls the heated seats?
Old Jan 22, 2006 | 03:58 PM
CLETUS's Avatar
CLETUS
no you remove the console and unplug the yaw sensor, this deisables vdc bc the sensor is not telling the car which way the *** end is swinging around, yet the abs system is still active. the sensor is to the left of the coin holder but under the console..........atleast this is what i have read on hte internet........
Old Jan 22, 2006 | 04:07 PM
iyah's Avatar
iyah
Talking
Originally Posted by itburns
You would all be surprised at how many buttons have secret functions when you hold it for a few seconds. I could tell you some but better you find out for yourselves. And I'm not just talking about the Z, but the whole world in general.
This reminds me did you know if you hold the Unlock button for about 8-10 seconds on your keyless remote the windows will go down.! They will stop as soon as you let go. (Does not work the other way, windows will not go up, I tried)
Old Jan 22, 2006 | 04:22 PM
CLETUS's Avatar
CLETUS
wow its amazing the "secrets" you can discover by reading the owners manual
Old Jan 22, 2006 | 04:55 PM
iyah's Avatar
iyah
NO No don't tell them where I get my secrets from!!
Next Time on Hidden OM Secrets
**Just what is that Shift lock on 5AT,WHAT DOES IT MEAN!! Till Next Time.
Old Jan 23, 2006 | 06:19 AM
buho62's Avatar
buho62
OK, then can someone explain what exactly the VDC off button does?
I mean I know if its on I can't fishtail the car, when its off I can fishtail. I understand it doesn't completely disables the VDC, but I want to know what is left on.
I'd really appreciate if someone that knows explains it!.
Thanks
Old Jan 23, 2006 | 11:06 AM
CLETUS's Avatar
CLETUS
Vehicle Dynamic Control- a computer program that looks at wheel speeds, throttle input and the yaw (or side to side movement) to dettermine if the car is under control. the program will cut throttle and/or apply the brakes based on inputs to get the car straight again. this is why you cannot swing the *** end around with vdc on. spinning wheels and teh yaw sensor tell the program that the car is not under control and throttle is cut. unplugging the yaw sensor will allow for burnouts and drifting with abs stilll active.
hope this is clear enough. this is how vdc, mercedes & chrysler's ESP and many other traction control programs work.
Old Jan 23, 2006 | 09:48 PM
rolling's Avatar
rolling
hey jason is this the same with the 06?
thanx
Old Jan 26, 2006 | 07:16 AM
buho62's Avatar
buho62
Originally Posted by MovingViolation
Hold the button down for an extra 15 seconds and you can open the secret entrance to the Bat Cave under Wayne Manor.
OK, it was Feb 2007 when I tried this, but I held down the button too long and the car started going too fast, there was a sonic boom and all the sudden somehow I'm in 2006 again!! How do I go back to 2007 now?????
Old Jan 27, 2006 | 12:08 PM
cal_z's Avatar
cal_z
Talking
HAHAHAHAHA
Old Jan 27, 2006 | 08:09 PM
itburns's Avatar
itburns
Thanks
Believe me, even with the VDC on, you CAN fishtail the car. It just takes a little more effort.
Old Jan 28, 2006 | 02:05 AM
bleunetizen's Avatar
bleunetizen
as far as i know, turning VDC off does turn off the VDC completely, but it does not disable the brake assistant.
For those you who CANT fish tail or get it sideways probably is because you hit the brake at some point.
Try this, may be at a large car park or somewhere you can do this safely, with VDC turned off -
at around 80~100k (50~60mph), shift to 2nd and DUMP the clutch then full accel while turning your steering wheel slightly towards open area, make sure you have enough space because your might spin out if you don't react fast enough afterwards. If you do this right, your rear end will break out instantly, and you can start fish tailing or drifting or whatever after that.
Now, do the same thing, but touch the brake slightly before full accel after shifting into 2nd gear, and also try heel and toe braking to 2nd gear then do the same thing.
If you TOUCH the brake before full accel, the car will not break the rear loose at all. It does feel somewhat twitchy but the car doesnt really accelerate enough to kick the rear out. Im not sure if its VDC closing the throttle body or the brakes biting automatically, but this is sometimes disturbing.
I never tried disconnecting the G sensor in the centre console, but I heard people saying it will completely disable the VDC. But I am guessing that it is disabling the brake assisant thing rather than disabling the VDC because the stability control system (VDC or brake assistant or whatever) does not work unless I touch the brake.
Anyone experienced this?
Old Jan 28, 2006 | 03:45 AM
350ZTrackspec's Avatar
350ZTrackspec
To set you all straight........When you press VDC to turn it off yes you can go sideways. But if you in the middle of a slide and you tap the brakes wether you like it or not VDC will kick in.
Hope this helps.
Maybe with this new hold it down for 10 seconds thing it might turn it off completely even if you go on the brakes during a slide. Ill give it a go
Old Jan 28, 2006 | 07:07 AM
A_16's Avatar
A_16
just tried this out guys...........held it down for 10 seconds........light went off..........redlined first..........TRACTION CONTROL
Old Jan 28, 2006 | 09:25 AM
super_fla's Avatar
super_fla
you are completly right, but correcting little information of yours:
using brakes in the middile of a drift doesn't active the VDC. in fact what happenes there is the EBD (Electronic Brake Distribution) system. i don't know if some of you heard about it before or not! but our cars do have that system. its not the same thing which called BS ( brake assistance) that also availble in the Z. brake assistance system is a system that works as a brake booster when applying the beakes hardly,
EBD system ditribute the brake force on each tires depending on each wheel speed and maybe the yaw sensor to avoid going sideways.
peace
Old Jan 28, 2006 | 09:39 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
That's the Yaw rate/side G sensor.
aarrgghh
May 1, 2022 11:04 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
