Need a little advice about exactly how to set shift indicator
It's hard for me to do this precisely because I am usually not watching the tach when I'm going at WOT.
I react to when the shift light starts blinking, not when it becomes solid.
I want the shift light to START blinking about 300RPM before redline, so I can react and shift properly. What should I set it at?
Thanks guys.
Thanks guys.
see when it starts blinking in relation to turning red at low rpm, then do the math and apply to the redline. If it starts blinking at 1k when you have it set to 1500 then it is 500, I don't know the number but come on how hard is it to figure out.
Originally Posted by mc350z
i have mine set to 6600. arnt you supposed to shift as the blinker turns soild
Originally Posted by indierock
I Just learned how to drive stick and everyone tells me to not let the rpm go over 3.5-4.0, so i usually shift up when its just about 3,200. is this what i should be doing? Please someone explain to me. thanks.
mine is set at 4500, even though i shift at 5-6 even redline sumtimes. i just like that red light =) but if you want it to BLINK at 3000 then set it at 3500. if u want it at 4200 then set it at 4700, etc. if you want to turn the red light off set it above 7400
