Vibration from Bass?
Old Jan 31, 2006 | 11:44 AM
JCA0688's Avatar
JCA0688
Default Vibration from Bass?
I have the standard bose system with the single sub behind the diver seat. And whenever I play a song with strong bass (Whisper Song for example) I hear a lot of vibration through the car. Should I be worried, or is this just normal for a car with lots of bass in it?
Old Jan 31, 2006 | 11:46 AM
angelzhope720's Avatar
angelzhope720
You're going to get flamed. I have 2 kicker Comp VR's running at 600 watts one channel. You think YOU have a lot of bass? Whenever I leave my subs on for more than a minute my rear view mirror is facing my shift ****.
Old Jan 31, 2006 | 11:49 AM
JCA0688's Avatar
JCA0688
I never had a car with lots of bass or subs at all. I just wanted to know what to expect having them.
Swiffer's Avatar
Swiffer
This is normal. With any car, when you add quite a bit of bass, you will get rattles. You can fix it by tracking down where the rattle is coming from and applying some dyno-mat or similar product.
max255's Avatar
max255
I know man really, what the heck are you talking about. The vibrations are the only reasons I listen to rap, and the only reason people buy subs.
Old Jan 31, 2006 | 11:51 AM
JCA0688's Avatar
JCA0688
Theres a difference between vibration of the actual music(beat), or the rattling and vibration of the plastic in the car. I particular don't think those noises go well with the song.
Old Jan 31, 2006 | 11:55 AM
max255's Avatar
max255
well then if thats whats rattaling then you need to find a higher quality car.
Swiffer's Avatar
Swiffer
You can stop the rattles caused by the pieces of the interior by placing a piece of foam or dynomat under them.
Old Jan 31, 2006 | 11:56 AM
JCA0688's Avatar
JCA0688
Dynomat = ?
Old Jan 31, 2006 | 11:59 AM
Silkk's Avatar
Silkk
Search = ?
Paul350Z's Avatar
Paul350Z
Living in 350Z
Dynomat is a bit of thick and heavy asphalt based material with a sticky side and a foil side. Here's some of the treatment I added. This is a product called "Fat Mat" which is the same material half the price without the logos.
Old Jan 31, 2006 | 02:25 PM
johnk024's Avatar
johnk024
welcome to world of sound waves
Old Jan 31, 2006 | 02:35 PM
TeCKNeiC's Avatar
TeCKNeiC
My trunk vibrates and rattles but that's why I bought the two 10's. I think it is normal and even gets the honey's to look over when you roll up next to them and your bass rattles their ride too.
Old Mar 21, 2006 | 10:34 PM
Dream's Avatar
Dream
I'd rather my car be nice and quiet while rattling someone else's car. Rattling trunks sound ugly to me, like those ghettomobiles you see in the Mainland where the trunk sounds like baseball bat-wielding midgets are trapped inside trying to get out.
Old Mar 22, 2006 | 07:17 AM
overZealous1's Avatar
overZealous1
i got 100'sq for $100 on ebay. smoking deal on the fat mat. the rattling in your door panels is from the door speakers not the sub. chances are it isn't even a rattle, but you have the bass turned up too loud and are popping the door speaker. i tried to fat mat my doors and it is pretty much done from the factory.
Old Mar 22, 2006 | 07:38 AM
TeCKNeiC's Avatar
TeCKNeiC
Just found out my trunk isnt rattling. The rear lisence plate is not screwed down properly so that it the only thing that is vibrating...
Old Mar 22, 2006 | 09:19 AM
tmounk's Avatar
tmounk
I have the same set up in my car with the bose sub, and the rattling that I have comes from the dash board and it's not from the music. It rattles at speeds under 25 mph. ??????????
Old Mar 22, 2006 | 11:16 AM
[]V[]addog's Avatar
[]V[]addog
ha ha. that is a nice comarision.
I'm a fan of nice clean crisp bass. Doesn't need to blow your trunk off, but shoudl be a nice full sound.
Old Mar 22, 2006 | 12:07 PM
ANXIOUZ's Avatar
ANXIOUZ
Bass should sound and feel good...without rattling anything. Once you start to rattle, you're just making a fool of yourself.
Old Mar 22, 2006 | 12:33 PM
Ichigo's Avatar
Ichigo
Sound deadening material serves more purpose than curing the rattles. It also helps keep you sound waves generated by your stereo where you want it, Inside your car. It will also keep road noise out. its a worthwhile investment if you find the level of road noise in your car annoying.
CrowzRSA
Sep 21, 2015 04:00 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
ZZ3.5
Dec 2, 2002 07:35 PM
someone
Nov 19, 2002 08:38 PM
Zedagive
Oct 27, 2002 03:26 PM
