LEDs in the Engine Compartment?
Old Feb 17, 2006 | 08:05 AM
Villainous350z's Avatar
Villainous350z
Default LEDs in the Engine Compartment?
Has anyone done this yet? I want to install LEDs in the vents of my hood I am wondering how they stand up to the heat and if anyone has any suggestions?
Thanks!
Old Feb 17, 2006 | 08:07 AM
lax91181's Avatar
lax91181
post here www.jdmcivic.com/ to find out
Old Feb 17, 2006 | 08:16 AM
sq40's Avatar
sq40
LEDs hold up well under the hood.
My advise to you is to buy a simple Hood/Pin Switch (about $3) from any store that sells car alarms and hook the ground to your LED set to this. This will break the contact and shut off the LEDS when the hood is closed and light them up instantly when open.
Old Feb 17, 2006 | 08:21 AM
Villainous350z
Yeah thought about the switch but I actually want them to beable to run when the hood is closed as well so I will show through the venting of the Scoote hood
Old Feb 17, 2006 | 08:42 AM
sq40's Avatar
sq40
LEDs don't drain a lot of power, My friend has about 10 under his hood on his cougar and lets them run full time without a problem. He never lets his car sit for more than 2 or 3 days, so I think you would be good to go.
Old Feb 17, 2006 | 09:01 AM
Villainous350z
Yeah I am going to run a switch into the cockpit of the Z to control the outside lighting. I am also having LEDs mounted into the vents of my GReddy side skirts.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
