Everything Install
Old Feb 18, 2006 | 01:36 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by rockinbboy
That doesn't sound too bad for 800 bucks. Hmmmm <thinks>.........
lol...damnit..
I highly suggest it!!! I'm very happy with everything. Keep an eye out for the dyno sheets of the gains.
Old Feb 19, 2006 | 09:49 AM
indierock's Avatar
indierock
Originally Posted by Robert_K
Well I have everthing install. The mods I did I consider all the "Best Bang for the Buck N/A Mods". The mods consist of; JWT Pop Charger w/ Heat Shield, UR Ultra Underdrive Crank Pulley w/ Gates belts, Motordyne 5/16" Plenum Spacer and Iso-Thermal Gasket Kit, and APS Cat-Delete Race Pipes. Total for these mods are around $800. Everything you can install yourself or with a friend. I suggest for the Test Pipes you have access to a lift. The lift just make it a bit easier to work under the car.
I have to say I love everything. All these parts helped the car. The power gains are defently there and the exhaust note is much better (IMO). The car runs smoother powerband now also. The Race Pipes do give the note a bit of a rasp but nothing I couldn't live with. I personally think these four mods should almost be considered a Stage I Kit for those that plan on staying N/A.
Overall: I'm very happy with my chooices and very happy I did the research before buying. I'll be back on the Dyno on the 25th to see the gains. Hoping for around 240ish whp and 235ish wtq.
Next on my list are: StopTech Stage II Brake Kit & Nismo Cat-Back Exhaust. Ingalls Engineering (http://www.ingallseng.com/) & I are working on some suspention components.
Hmm, i am actually pretty interested in modding my car but nothing to extreme. Keep in mind that i know absolutely nothing about modding. This setup you have sounds like it makes a huge difference. What are the pros and cons to doing this to my 2003 Z MT? (Peformance version i believe)
Old Feb 19, 2006 | 10:05 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
All this has been done to a '03 Touring 6sp. The pros as you can see, & will post dyno results next week, are good power gains for a minimal amount of money. Also everything is a bolt-on, you can install everything yourself or with a friend. You don't have to worry about doing damage to the car or engine.
The only cons I can see as far as doing this route:
-The engine becomes louder. Some might not enjoy the louder engine at higher RPMS.
-The test pipes do add a rasp to the exhaust note and are not legal.
-You're spending money you "could've" save towards F/I.
I still stand behind this as a "Performance N/A Stage I" set-up, "Best Bang for the Buck."
Old Feb 19, 2006 | 02:08 PM
drewby's Avatar
drewby
Arrow Hp
Hi, what power gains do you think you will get, with the pop charger, spacer, & decat pipes, & do you have a link, with imfo on the pulleys, what extra power would you expect with free flow Y pipe & system. thanks. D
Old Feb 19, 2006 | 02:14 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I'm shooting low and hoping high as far as gains. I'm thinking I'll be at 240ish whp and 235ish wtq. What info would you like on the pulley? Olny thing I can recommend about the pulley is get the Gates Belts!!!
For more info:
http://performancenissanparts.com/ca...roducts_id=260
http://www.unorthodoxracing.com/uS.html
As far as the Y-Pipe I'm doing research on that right now. I have just heard that the APS TP w/ Nismo Cat-back doesn't sound too good. Also that just a Y-Pipe give nice gains for minimal price.
Old Feb 22, 2006 | 10:55 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Whoo-Hoo!!! Two more days till I'm back on the dyno.
Old Feb 24, 2006 | 07:58 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I'll be posting number up tomorrow night.
Old Feb 24, 2006 | 09:25 AM
twinship's Avatar
twinship
What does the "seat of your pants" dyno say?
More HP/torque? Gains at low RPM, high RPM, throughout?
Just wondering cuz that looks like a good combo...
Old Feb 25, 2006 | 07:37 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Robert_K: '03 350Z Touring 6sp, 249.45rwhp, 236.49rwtq, 25-Feb-06 Mac Autosport, Dynojet, JWT PopCharger, UR Ultra Underdrive Crank Pulley w/ Gates belts, Motordyne 5/16 Plenum Spacer and Iso-Thermal Gasket Kit, and APS Cat-Delete Race Pipes
Gained 17rwhp & 10rwtq!!!!!
Old Feb 28, 2006 | 09:55 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thread with dynograph: https://my350z.com/forum/2003-2009-nissan-350z/174222-gained-17rwhp-and-10rwtq-n-a.html
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
