premium gas..
Old Feb 25, 2006 | 05:46 PM
zand02max's Avatar
zand02max
Originally Posted by ObiRedKenobi
Go find out the difference in higher octane gas and lower octane gas then reread the manual.
It says you can use 87 octane in it but don't take it over I think it was 4k rpm I could be wrong.
Cheap bastard 3-4 dollars a tank won't kill you.
I have never read that in the manual!
Old Feb 25, 2006 | 06:03 PM
DesiZ_06's Avatar
DesiZ_06
me niether...
Old Feb 25, 2006 | 06:05 PM
Fletch69z's Avatar
Fletch69z
Wow, I can't believe I just wasted 1 minute reading this post....
Old Feb 25, 2006 | 06:43 PM
DesiZ_06's Avatar
DesiZ_06
sry!
Old Feb 25, 2006 | 08:01 PM
cessna's Avatar
cessna
Simple question, simple awnser....
If you fill your tank up with the Reg, you'll probably be able to hear detonation (akainging sound from engine)
This is due to the lower octane level, which in turn combusts faster (at a lower temp) than premium would....
Hope that helps...
Old Feb 25, 2006 | 08:38 PM
rockinbboy's Avatar
rockinbboy
Originally Posted by Nismo 350z
Your posts are a waste of bandwith.
This guy is a post *****. I mean 40+ posts a day...WTF...get a life. Go drive your Z..don't hurt anyone in the process.
Old Feb 25, 2006 | 08:50 PM
max255's Avatar
max255
just don't sell me the Z when I go to look for one next year.
Old Feb 25, 2006 | 09:14 PM
maddog8024's Avatar
maddog8024
Octane is an additive to fuel to help prevent detonation, the higher the octane the harder it is to detonate, this is needed in higher compression ratio applications, most cars have a compression ratio of around 8:1 which is fine to run regular, in fact it would be a waist of money to run regular in a car like that, the Z has a compression ratio of 10:1 and this is the range requiring higher octane fuel to prevent premature detonation. The higher the compression ratio in general the greater horsepower per liter that an engine will produce in naturally aspirated applications. The Z like many other cars has an anti knock sensor that will retard the timing to PREVENT DAMAGE to your engine, and this reduces the compression ratio and in turn reduces horsepower. Don’t be a cheap A$$, run premium, get the max out of your car. And if you ever want to sell your z, well I know I wouldn't buy it if I knew it was ran on cheap gas for an extended period of time.
Old Feb 25, 2006 | 09:31 PM
Sven's Avatar
Sven
Thanks for putting that issue to rest! With that many posts a day, how the phuque do people have time to drive the Z?
Old Feb 26, 2006 | 07:33 AM
DesiZ_06's Avatar
DesiZ_06
is running on regular gas a bad thing since november? i think im gonna go for premium now
Old Feb 26, 2006 | 07:45 AM
zrausch's Avatar
zrausch
Most of those people are posting while at work or school and have nothing else to do but just sit there.
Old Feb 26, 2006 | 09:16 AM
jrod1014's Avatar
jrod1014
Old Feb 26, 2006 | 10:32 AM
Sven's Avatar
Sven
True. True.
Old Feb 26, 2006 | 10:33 AM
"Z"orilla's Avatar
"Z"orilla
Thumbs down
If you have been running REGULAR gas since November, why are you asking now?
Some people shouldn't be given a driver's license. Listen Forrest, run back to "MOMMA" and "LIEUTENANT DAN" and eat your "box of choc-co-lates" and leave the discussions about the 350Z for the big boys, okay snook'ems!
Old Feb 26, 2006 | 10:43 AM
steela2110's Avatar
steela2110
you must use premium! It is in the damn manual for a reason!
Old Feb 26, 2006 | 11:41 AM
vroom350z's Avatar
vroom350z
yes please use premium and watch your driving because i dont want higher rates because of more totaled z's
Old Feb 26, 2006 | 02:19 PM
changsw's Avatar
changsw
Premium gas (91 octane) has a higher compression yield than the regular gasoline (87 octane). Because the Z has a higher compression engine (I forget the ratio) than most cars (passenger cars), it needs this extra yield.
During the compression stroke, 91 octane can resist a premature explosion. Using 87 octane may cause the air/fuel mixture to explode early, hence engine knocking.
The manual says that if you really need to, you can use 87 for a little bit, but must refuel with 91 ASAP. Plus 91 octane is only 20 cents more expensive, if you can afford a Z, you can go that extra step bud.
If your mommie bought your car for you, you're spoiled and you can use 87 octane.
Old Feb 26, 2006 | 03:54 PM
  #38
dcmidnight's Avatar
dcmidnight
Put in diesel, I hear its the best, my brothers friends uncles mothers boyfriend said it was. Try it for a few tanks and let us know how it works out...
Old Feb 26, 2006 | 04:06 PM
  #39
Z_Driver's Avatar
Z_Driver
Master
Read page 9-3 of the owners manual.
Basically states use 91 ron or above.
If 91 ron isn't available you can use 87 ron temporary in the following conditions:
1. That you fill up the tank only partially and then you fill up with 91 ron as soon as possible.
2. Avoid full thottle or abrupt acceleration. (Knock is the worry here-Damages valves and pistons.)
Not good, not good at all.
pslamp32
Feb 8, 2017 09:07 AM
Calinismo350z
Sep 14, 2015 04:04 PM
Chebosto
Aug 6, 2003 06:31 AM
Rob Nance
Mar 17, 2003 11:49 AM
k2we
Oct 4, 2002 02:42 PM
