Brake light
Old Mar 8, 2006 | 11:44 PM
NzZ's Avatar
NzZ
Default Brake light
Hey guys,
Over the past 2 weeks I've noticed that whenever I pull high G's (braking, cornering, accelerating) my brake light comes on. Checked the fluid, it was fine. The pads have been squealing a bit more than usual. Took it in to the dealer to have them take a look at the pads/rotors (I don't have a jack at my apt and don't trust my Z's scissor jack anymore)...dealer called me today and said "plenty of pad left, plenty of rotor left."
I'm not sure what could be causing my brake light to come on, much less the squeal that's been going on. Should I take it elsewhere for a second opinion? Any suggestions?
Thanks,
NzZ
Old Mar 9, 2006 | 02:21 AM
paulsmansfield's Avatar
paulsmansfield
Do you mean the actual brake lights on the rear of the car or the warning on the dashboard?
If the actual lights then its probably a faulty switch.
If its on the dash then your brakes are probably worn or have a malfunction of some kind
Old Mar 9, 2006 | 02:23 AM
Sean's Avatar
Sean
just a WAG, but could it be an issue with your ABS?
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
