Highbeam Healight Noise
Old Mar 10, 2006 | 06:02 PM
SDC's Avatar
SDC
Default Highbeam Healight Noise
Ok, I know this may seem like a "No Brainer" to most of you but I have had my 06' Z Touring for about 2-3 weeks now and just recently had to turn on the Highbeams. When I click from low to high beam there is a very audible clicking noise from the headlight area. Has anyone else experienced this? Is this normal? Any help would be appreciated.
SC
Old Mar 10, 2006 | 06:23 PM
Kolia's Avatar
Kolia
The '06 headlight are bi-focal HID.
It's one light bulb that moves up and down (or a mirror or what ever) that changes where your beam is aimed. An electric actuator does that. So it can make noise.
If it's really noisy, your dealer will fix/replace it with pleasure I'm sure.
Old Mar 10, 2006 | 06:26 PM
6swhite350z's Avatar
6swhite350z
2006 G35.. same noise. not a problem. no worries
Old Mar 10, 2006 | 06:31 PM
rockinbboy's Avatar
rockinbboy
How are you guys listening for this? Do you put your head by the light and have someone flick the high beams on and off? I mean, I don't hear anything but I am inside my car when I turn my high beams on.
Old Mar 10, 2006 | 06:35 PM
Kolia's Avatar
Kolia
You have to run real fast...
Seriously, It would be nice to see a picture of the light distribution on a '06 Z.
Is it good? The previous years, like my '05, the high beams are added to the low beam HID. It make a LOT of illumination!
Old Mar 10, 2006 | 07:16 PM
SDC's Avatar
SDC
Default Headlight Highbeam Noise
Thanks to all for your replies. The noise is very loud and noticable in and out of the car so I think I will make an appointment with the dealer to have it checked out..
Old Mar 10, 2006 | 07:37 PM
InSaNeZ's Avatar
InSaNeZ
I love these bi-xenons, i bet the other drivers don't
Mine makes the same noise, but it's not too loud
Old Mar 10, 2006 | 08:04 PM
6swhite350z
you can hear it from the cockpit. turn ur car off, turn ur radio off... turn ur light off, then flick on the high beams
Old Mar 10, 2006 | 08:56 PM
risin's Avatar
risin
I believe that each headlight housing has 2 hid bulbs and when the high beams are selected the cover over the high beams are removed.
Yes my high beams make noise too, but it isn't something that worries me.
The lighting is really really good on the 06, compared to the 05.
Old Mar 11, 2006 | 09:02 AM
Russ@Z1's Avatar
Russ@Z1
if it bothers you, i'll graciously trade you my headlights and i will take your 'noisy' headlights as an even exchange.
Old Mar 11, 2006 | 10:46 AM
Fletch69z's Avatar
Fletch69z
I love that my 03 does that too. High beams on top of regular head lights. Like a BMW, .
Old Mar 11, 2006 | 11:31 AM
supra crazy's Avatar
supra crazy
You're a little off there, buddy. The Bi-Xenon projectors dont have 2 bulbs, that'd be ridiculous. Inside every projector, there is a shield, that's what create the cutoff, by blocking unwanted light with a shield. Now in a bi-xenon projector, when you turn on your highs, the shield flips inside of the projector allowing out the full light of the projector. What you hear, is the solenoid flipping the shield.
Old Mar 11, 2006 | 01:36 PM
risin's Avatar
risin
Ok, bixenon means it has 2 lights in 1 unit but still has 1 filament. If that makes any sense.
Old Mar 11, 2006 | 01:45 PM
new_one's Avatar
new_one
it's the solenoid
Old Mar 11, 2006 | 07:42 PM
supra crazy
No. There is not 2 units. Do your homework on HID's. There isnt even a filament. An HID bulb is considered a capsule, its not even really a "bulb".
1 Bulb, 1 Projector, 1 Solenoid, 1 Shield.
Old Mar 11, 2006 | 07:47 PM
Gryphin's Avatar
Gryphin
high
low..
I was adjusting they are much wider now..
Old Mar 11, 2006 | 09:09 PM
Chad68's Avatar
Chad68
I hear it from low beam to high beam easy. Kind of a thud sound
Old Mar 12, 2006 | 12:00 AM
imseksy's Avatar
imseksy
i thought it was normal for 06?
Old Mar 12, 2006 | 02:23 AM
Kolia's Avatar
Kolia
Thanks Gryphin. Looks good!
Old Mar 12, 2006 | 06:53 PM
Chad68's Avatar
Chad68
My '06 does it and so did the other '06's I looked at.
