When you dyno in 5th or 6th you get too much heat soak. I would suggest 3rd or 4th.
Heat soak isnt a problem unless your boosted and have an inneficient intercooler, bad advice man. 5th is the 1:1 and the correct gear for a 6MT Z. Generally most Z's dyno higher in 5th than 4th, because it takes longer to dyno, more air gets into the cylinders, thus making slightly more power than in a lower gear)4th) where the dyno goes by quicker. 3rd gear for a 6mt dyno is just ghey
