HELLO , I'm a NEWBIE, what's everyone's first mod?
Old Mar 16, 2006 | 11:54 PM
6swhite350z's Avatar
6swhite350z
i dont get know the plenum spacer adds hp.. ? breif explanation plz
Old Mar 17, 2006 | 12:26 AM
deviljon's Avatar
deviljon
what the hell did you just say?
Old Mar 17, 2006 | 06:12 AM
richardho11's Avatar
richardho11
LMAO!!
Old Mar 17, 2006 | 06:50 AM
ANXIOUZ's Avatar
ANXIOUZ
Originally Posted by fairlady350z33
Thanks Murphy, does the Pop-charger sound deep? or does the NISMO sound better? who ever has one, please chime in. Either way I heard pop charger is the best.
Intakes don't add a deep sound...exhausts do that. Intakes usually add a sucking sound while accelerating and (slightly) increase the volume of the engine at higher RPMs.
The Nismo sounds way better than the JWT but it's also more than twice as much. Since neither really give you any HP you might as well go with the JWT like 90% of the people here. If we all have it, it must be decent right?
Old Mar 17, 2006 | 07:43 AM
deviljon's Avatar
deviljon
does anyone here have the gruppe-m intake? how does it sound? for 900 dollars it better sound insane...
Old Mar 17, 2006 | 08:46 AM
sry110's Avatar
sry110
I just got my '06 a week ago and I think my first mod will be a new sound system. I am waiting for the new Alpine HU's to come out at the end of this month so I can get the one I want with their Biolite display (i.e. won't wash out in the sun like all their earlier units). Plus it is steering wheel control compatible...w00t.
I came from owning a mazda6, so I don't need to add any more sound or power at the moment. My theory is that if I get used to the sound and power of a new intake and/or exhaust right from the start, where do I go from there? Also, I don't plan on turbo or super charging. I'd rather wait a little bit, but in the meantime the stock sound system suuuuuuuuuucks!
Old Mar 17, 2006 | 09:26 AM
godzilla619's Avatar
godzilla619
Been driving my enthusiast for almost a month. Put in the nismo radiator the first week. Really liked the Nismo embelm under my hood so got the CAI. Pretty easy to install too. Made the car sound better and accelerate quicker at the top end. Plus with all the rain lately it is nice to know that it has the bypass so your engine doesn't hydrolock. Going to put on tinted side reflectors, and maybe tint the windows this weekend. After that probably an exhaust system. Does anyone recomend any daul exhaust systems? I just like the look of the dual. I like the Greddy center mount too, but you have to get thier rear valence for it to work.
Old Mar 17, 2006 | 09:28 AM
Fa1rLadyZ's Avatar
Fa1rLadyZ
Originally Posted by lax91181
My first mod was finding the search function. There are answers to all of your questions within the search function.
+ 1
Old Mar 17, 2006 | 10:09 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you want to look at a bunch of mods available, check out www.mynismo.com
they have plenum spacers, JWT popcharger, clutches, exhausts, cams, turbo kits, wheels, whatever the hell you want.
THEN read up on the engine/drivetrain/forced induction forums...
then if you still have questions, use the search feature.
If you can't answer your questions by searching, try posting there. The main 350Z forum is mostly for newbs and spam
Old Mar 17, 2006 | 11:42 AM
fairlady350z33's Avatar
fairlady350z33
Thanks for all the helpful advice you guys, i know the pop charger doesn't make a deep sound like an exhaust. I just mean which one has a deeper tone when you step on it. like the injen cai i had on the maxima makes a whimpy sucking noise compared to the stillen under the hood intake. thanks for all the input. i will be getting the JWT.
as for the s2000 antenna? did you guys get it from ebay? how much did you pay? same for the tint. how much does it run for a good tint on the 350Z, like a platinum one? how much did you pay?
THANKS everybody, especially for the link to the motordyne site.
Old Mar 17, 2006 | 11:48 AM
fairlady350z33
sorry guys one more quick question? do you have to very mechanically experienced to install the spacer? do i have to go under the car?
thanks, the most experience i have is installing CAI and strut bars? how much harder is this?
Old Mar 17, 2006 | 01:28 PM
seanHouston's Avatar
seanHouston
Skunk2 Intake Plenum Spacer
Applications: 350Z, G35, FX35
This spacer fits in between your stock upper and lower intake plenums on the engine, creating more intake air volume, and cooler intake air temperatures. This spacer is different than other spacers available. This spacer is made from a special carbon composite material which helps with the standard heat soak issues common in metal intake manifolds.
Create power by lowering intake temps. and creating more intake volume with this newly designed spacer.
Old Mar 17, 2006 | 01:29 PM
seanHouston
http://performancenissanparts.com/ca...oducts_id=5573
Old Mar 17, 2006 | 01:32 PM
fairlady350z33
Thanks seanHouston, is the skunk one a 5/16 and will it fit under the sway bar? is this better than motordyne? who has this and who has motordyne.
Old Mar 18, 2006 | 01:04 PM
Tokyo Mike's Avatar
Tokyo Mike
I think the first mod should be the DRIVER mod. Learn how to drive the car before you start modding. It will handle and respond a lot differently than your Maxima. Then later when you get the feel for it, then start adding some performance mods. You will appreciate them more. Since your in SoCal, do some track events...Streets of Willow is the closest. It will be well worth it! Just my 2.
Mike
Old Mar 18, 2006 | 02:11 PM
roast's Avatar
roast
Mike
+11111111111111111111111
Old Mar 18, 2006 | 03:00 PM
Osix350Z's Avatar
Osix350Z
I have had my 06 revup since NOV. First mod you should do is the MREV plus kit from motordyne. It is a waste to just do a Plenum spacer on the REVUP motor. The 06 MTs lack torque, which is gained considerably by the Machined lower collector that comes in the MREV plus kit. It also comes with a copper throttle body spacer and the 5/16th spacer and gaskets. This mod IS the best bang for the buck, you will gain more power with this mod and spend less money than i/h/e. Minimum is like 15 rwhp and 18ft pounds TQ.
Give Tony a shout down at Motordyne, the MREVplus kit is a must have for the REVUP motor.
Old Mar 18, 2006 | 03:32 PM
  #38
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I gained 17whp & 10wtq with mods in sig.
Old Mar 18, 2006 | 06:54 PM
  #39
03zcarfl's Avatar
03zcarfl
1st was nismo headers, kinetix high flo cats and nismo exhaust, tein ss coilovers, and cold air intake, and 19x 8.5 racingharts j8 in front and 19x10.5 in rear, seibon carbon hood and carbon creation carbon wing, jc custom headlights, and custom tailights, Tv and alpine dvd... but mine is a base model so I had to hook it up. still need some damn subs and surround sound great for movies. geeting new clutch and flywheel this week can anyone suggest one to me. it is a daily driver so I still want comfort but as of now my car sits @ a dealership in miami broke down needing a clucth and flywheel replaced and they want $$2500 for the job with stock parts I m thinking aftermarket stage one for now. anyone can help let me know
Old Mar 18, 2006 | 10:30 PM
  #40
tienlo's Avatar
tienlo
Most of the people on this forum do a front end conversion to a BMW 3 series.
