DIY Maintenance
Old Mar 23, 2006 | 03:09 PM
nesh216's Avatar
nesh216
Default DIY Maintenance
For those of you that do some maintenance on your Z yourself, like change the oil; do you also take it to the dealer for the scheduled maintenance?
I have a 2005 Z with around 10,500 miles on it. I have been doing all the oil changes and haven't gone to the dealer for service yet. Would you recommend me taking it in per the service manual and just not have them change the oil?
Old Mar 23, 2006 | 03:58 PM
Cannysage's Avatar
Cannysage
just oil changes. I'll get a checkup around 40k
- check breaklines
- replace fuel filter
- maybe start using synthetic oil
- check the shocks, if I still have stock ones
- change or clean airfilter/cai
at 120k prolly will change a lot more if I still have the car.
Old Mar 23, 2006 | 04:22 PM
jakesford's Avatar
jakesford
dealer maint for the most part is a rip... Most of it is just visual inspections, if you can change fluids and do basic tune up work you will be fine.
That being said, it looks good for resale if you can provide dealer maintance records. You can do some this your self by keeping receipts for oil, filters ect. and keep a small note book with dates that you did your own maintance. If you do your own brakes keep the receipts for pads, fluids, turning rotors or replacement rotors. You can make notes that you bleed the fluid, checked suspension bushing ect...
Old Mar 23, 2006 | 06:17 PM
+1. There is little point in paying someone to top-off fluids and check air pressure. When it comes time for, say, coolant replacement, you may want to have that done at a shop.
seagrasser
Oct 11, 2015 03:27 PM
NFAC
Sep 26, 2015 10:11 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
rizzla
Drag
Sep 17, 2015 08:44 AM
